Intel® C++ Compiler
7956 Discussions
How could I control the format of a macro __FILE__?
SergeyKostrov
Valued Contributor II
The name of the current source file is stored by a C/C++ compiler in ANSI-Compliant Predefined macro __FILE__.
How could I control the format? For example:
MinGW stores it as: ../../folder3/test.cpp
Visual C++ compiler stores it as: c:\\folder1\\folder2\\folder3\\test.cpp
Georg_Z_Intel
Hello Sergey,
AFAIK the way the __FILE__ macro is formatted depends on how you provide the source file names to the compiler, e.g:
file.c:
[cpp]#include
int main(int argc, char **argv)
    printf("%sn", __FILE__);
    return 0;
}[/cpp]
[bash]C:temp> icl file.c
C:temp> file.exe
file.c[/bash]
or
[bash]C:temp> icl C:tempfile.c
C:temp> file.exe
C:tempfile.c[/bash]
If you want both to be aligned there's a more general consideration:
MinGW uses POSIX paths (with slashes). I'm not aware that you can change VS to use POSIX instead. Maybe you can convince MinGW to use Windows paths (with backslashes). Unfortunately I've never tried that with MinGW.
Georg Zitzlsberger
SergeyKostrov
...Maybe you can convince MinGW to use Windows paths (with backslashes). Unfortunately I've never tried that with MinGW...
That would be nice. Thank you, Georg.
SergeyKostrov
Hi Georg,
I could replace all '\' with '/' in case ofVisual C++, but I can't reconstruct a full path in case of MinGW.
MinGW: ../../folder3/test.cpp
Visual C++: c:/folder1/folder2/folder3/test.cpp
Anyway, I'll decide if it makes sence to spend time onthese updates.
Sergey
