Intel® C++ Compiler
7952 Discussions
How do I compile OpenMP code in DevCloud?
gamersensual14
Hi Intel team!
I'm using the DevCloud to try out (and compile, because otherwise I wont be able to execute it) some SYCL and OpenMP codes.
The SYCL codes compile and work well but the OpenMP ones don't even compile. When I developed them in local, I used the compiler NVC, but it looks that it isn't on the DevCloud.
How can I compile my OpenMP code in the DevCloud? What compiler should I use in the makefile?
Thank you very much!
VarshaS_Intel
Yes, because NVC is an Nvidia compiler. In the Intel Devcloud, Nvidia compilers won't exist. You can use all the Intel oneAPI Toolkits and Compilers in the Devcloud.
You can compile OpenMP codes with Intel C++/Fortan Compiler. Please find the links for compiling the OpenMP codes:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/software-development-process/composability/c-c-openmp-and-dpc-composability.html
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-gpu-optimization-guide/top/openmp-offloading-intro/openmp-compile-and-run.html
Moreover, you can also use SYCL and OpenMP in a single code.
Please find the below link for the compilation and running of the code:
Thanks & Regards,
Varsha
VarshaS_Intel
Thanks & Regards,
Varsha
VarshaS_Intel
Thanks for accepting our solution. Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will
no longer be monitored by Intel.
Thanks & Regards,
Varsha
