Intel® C++ Compiler
7944 Discussions
How do I configure Intel C++ platform toolkit in Visual Studio 10
tj1
I downloaded evaluation copy of Intel C++ Composer XE for Windows (64 bit), but have problem getting it to run under MS Visual Studio 10. I followed the instructions in the getting started guide, to no avail.From Visual Studio 10 menu Tools > Options,I see the following:
Platform Toolset is Intel C++ Compiler XE21.1, Selected Compiler is
Compiler Information is: Intel C++ Intel 64 Compiler XE on Intel 64, version 12.1.5 Package ID: w_ccompxe_2011.11.344
However contrary to the getting started guide there was no option to select an Intel Platform under Project > Properties > General and I have tried typing in various permutations of Intel C++ Composer etc and I always get the same type of error, e.g.,C:\\Program Files (x86)\\MSBuild\\Microsoft.Cpp\\v4.0\\Platforms\\Win32\\Microsoft.Cpp.Win32.Targets(518,5): error MSB8008: Specified platform toolset (Intel C++ Compiler XE21.1) is not installed or invalid. Please make sure that a supported PlatformToolset value is selected.
Can anyone advise me what I need to do?
Tom.
JenniferJ
It's because you only installed the Intel C++ Composer XE pkg for x64 app. And your project in VS2010 is configured for "win32".
Right now you need to install the Intel C++ Composer XE pkg for IA-32 app. after that, it should work.
Although your machine OS is x64, but it can run both IA-32 app and x64 app.
The ICL for x64 can only generate x64 binary, and the ICL for IA-32 can only generate IA-32 binary.
Jennifer
tj1
Thanks very much, Jennifer, that's it working now.
