u29459@login-1:~$ cat build-thing.sh
#!/bin/sh
icc -v test.c
u29459@login-1:~$ cat build-thing.sh.o13018
# Date: Fri Aug 16 05:42:10 PDT 2019
# Job ID: 13018.v-qsvr-1.aibuilder
# User: u29459
# Resources: neednodes=1,nodes=1,walltime=06:00:00
# End of output for job 13018.v-qsvr-1.aibuilder
# Date: Fri Aug 16 05:43:22 PDT 2019
u29459@login-1:~$ cat build-thing.sh.e13018
Error: A license for Comp-CL is not available now (-15,570,115).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
** 1. /usr/local/licenseserver/psxe.lic
** 2. /glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/licenses
** 3. /opt/intel/licenses
** 4. /home/u29459/intel/licenses
** 5. /glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/bin/intel64/../../Licenses
** 6. /home/u29459/Licenses
** 7. /Users/Shared/Library/Application Support/Intel/Licenses
** 8. /glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/bin/intel64/*.lic
Please refer http://software.intel.com/sites/support/ for more information..
icc: error #10052: could not checkout FLEXlm license
u29459@login-1:~$
Thank you for reaching us.
We tried running a sample c code and it works fine at our end. Could you please share your workload if it is not confidential , so that we can try from our end.
This is the simplest example without just icc -v failing, with hopefully enough info to track down
why this login node won't compile, I'm using the compiler and paths that were pre-configured before
I logged in.
u29459@login-1:~$ echo $PATH
/glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/bin/intel64:/glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/mpi/intel64/libfabric/bin:/glob/development-tools/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/linux/mpi/intel64/bin:/glob/development-tools/versions/intel-parallel-studio/debugger_2019/gdb/intel64/bin:/glob/intel-python/python3/bin/:/glob/intel-python/python2/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/u29459/.local/bin:/home/u29459/bin
u29459@login-1:~$ date
Mon Aug 19 11:37:27 PDT 2019
u29459@login-1:~$ ifconfig ens5
ens5: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.2.0.1 netmask 255.255.128.0 broadcast 10.2.127.255
inet6 fe80::5054:ff:fe09:1 prefixlen 64 scopeid 0x20<link>
ether 52:54:00:09:00:01 txqueuelen 1000 (Ethernet)
RX packets 180914548 bytes 743989131199 (743.9 GB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 135799286 bytes 726357501325 (726.3 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
u29459@login-1:~$ uname -a
Linux login-1 4.15.0-46-generic #49-Ubuntu SMP Wed Feb 6 09:33:07 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
u29459@login-1:~$ id
uid=31459(u29459) gid=31459(u29459) groups=31459(u29459),1102(c002)
u29459@login-1:~$ cat test.c
#include <stdio.h>
main() {
printf("Tested\n");
u29459@login-1:~$ icc test.c
file has changed.
Could you please try out the below steps:
Go to bash_profile:
vi ~/.bash_profile
And then add the below command if it is not there
export INTEL_LICENSE_FILE=/usr/local/licenseserver/psxe.lic
And then source it using the below command:
source ~/.bash_profile
Now try to run your code and confirm us whether it is working, if not try from another terminal.
I already have that line set. Also, as it has printed out above, it has tried that file.
Perhaps it is because it can't connect to the flexlm server, on the host referenced in there ?
Maybe it's not on that port, needs a restart ?
Could you please check your mail, will continue this thread in email.
We are able to recreate your issue now. We are working on it. Will let you know once the issue is resolved. Sorry for the inconvenience caused.
Our team has fixed the issue. Could you please check and confirm us whether it is working or not.
Could you please confirm us if the issue is resolved.
Please be informed that the thread will get closed within 2 business days assuming that the solution provided was helpful.
Thank you for your response. As the issue got resolved we are closing this thread. Please feel free to open a new thread if you are facing any further issues.
After case closure, you will receive a survey email. We appreciate it if you can complete this survey regarding the support you received.
