Intel® C++ Compiler
7956 Discussions
How do you display a typename at compiletime with 11.1?
jlperla
For metaprogramming debugging, I frequently need the ability the print a type at compiletime, but some of the standard tricks don't seem to work. For example, boost::mpl::print doesn't seem to work with this compiler.
It would be nice to have the ability to do it without a compiler failure, but I will take a fail if I need to.
One of the usual tricks is to use an incomplete type. For example, the following kind of works:
template struct incomplete;
template struct print_fail : incomplete {};
etk::print_fail
Note that I cannot put a ";" at the end of print_fail, and a typedef of it doesn't work either or it compiles with no error or compile warning. It seems to me that if an incomplete type is not used, the C++ compiler ignores them and keeps compiling.
Any ideas on how to do this better or print without a failure?
Jesse
Judith_W_Intel
In order to get an error about the incomplete type you need to actually instantiate the template or use the type by creating an object, i.e.
etk::print_fail();
jlperla
Thanks!
Can you think of any tricks to get it to print a warning and not stop compiling?
Judith_W_Intel
If you're using icc (i.e. Linux or Mac) then you could use the deprecated attribute, i.e.:
template struct __attribute ((deprecated)) print_fail {};
int main() {
print_fail p;
return 0;
sptel5-345> icpc -c t.cpp
t.cpp(7): warning #1478: class "print_fail" (declared at line 4) was declared "deprecated"
print_fail p;
sptel5-346>
If you're using icl (Windows) I think you should be able to use the deprecated declspec.
Judy
jlperla
Thanks Judy,
I am on Windows.
I tried the following, but had no luck generating a warning:
[cpp]template  struct __declspec(deprecated) print_warning {};[/cpp]
[cpp]
int main()
  print_warning x;
  return 0;
[/cpp]
Judith_W_Intel
Sorry about that - that would work for a non template class butdoesn'tseem to currently work for a template class (I've submitted a bug report).
How about this?
!% cat t.cpp
template struct print_warning;
print_warning f(); // incomplete return type
int main() {
__alignof(f()); // Microsoft lets you use it in an unevaluated context with a warning
return 0;
jlperla
Thanks. That did it. Here is my macro if anyone is interested:
[bash]template  struct incomplete;
//The following needs to be used within a function!
#define ETK_PRINT_TYPE(T) {incomplete temp_print_##T(); _alignof(temp_print_##T());}
//Example usage:
int main(){
ETK_PRINT_TYPE(int)
[/bash]
JenniferJ
this issue has been fixed in compiler 15.0.
Now, icl will emit the warnings for both cases:
template <class T> struct __declspec(deprecated) print_warning_temp {};
int foo ()
  print_warning x;
  print_warning_temp<int> y;
  return 0;
