Intel® C++ Compiler
7956 Discussions
How does Intel compiler locate openmp headers?
Nav
I do not know how gcc finds the openmp headers either, but I guess the path would be set because openmp comes bundled with gcc.
But since the openmp header files don't come bundled with the Intel C++ compiler, how does the compiler find the files? I'm working on Fedora.
If GCC was not installed on my system, how would I be able to run openmp on the Intel C++ compiler? Would I have to download all the openmp headers, place it in a folder and specify an environment variable that will lead the compiler to that folder?
How would I go about doing it?
JenniferJ
Quoting Nav
Correction. The openmp header "omp.h" is included in the Intel C++ compiler. Please check the "/opt/intel/.../include" directory.
If you installed gcc as suggested by others, you should see "omp.h" is also provided by gcc. But you should use the "omp.h" from Intel C++ compiler if you'll build your app with it.
So to get it working, you'll need to do:
1. install the gcc and libs
2. install the Intel C++ compiler 11.1 for Linux
3. open a shell command window, source the "iccvarsXX.sh" to set up the correct environment
4. use "icpc" to build .cpp files or "icc" for .c files
Jennifer
aazue
Hi
About your remarks
(If GCC was not installed on my system .....)
If Gnu compiler is not installed you can not install or running Icc.
Kind regards
TimP
As Bustaf said, icc requires an active installation of g++, from which it takes most of the headers and libraries. It doesn't require openmp support in the g++, as it can use older versions of g++, so all OpenMP required headers are taken from icc's own include directory.
JenniferJ
Quoting Nav
Jennifer
Nav
Thanks Jennifer. I had a look at the omp.h of the Intel compiler. Interesting to know...
