Hello sir
How to do addition in intel processor 25468+358743 in binary
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Use Google to find your answers.
binary floating point
Gives:
https://ryanstutorials.net/binary-tutorial/binary-floating-point.php
https://www.youtube.com/watch?v=AU4DtxM9gb0
Jim Dempsey
Hello sir
please reply
1/9
hello
How to write it in binary
Gives:
Jim Dempsey
Hello sir
how to find 1/9 floating point how to convert it in 10010.1010
Binary is represented in powers of 2. 1/9 is a (decimal) fraction. You would convert this into a sum of binary fractions
1/2, 1/4, 1/8, 1/16, 1/32, 1/64, 1/128
To help identify which bit positions, first, as an example, compute 2^n / 9, where n is the number + 1 of significant bits of the precision of the result you want. Then look at the binary result and then place the binary decimal point to the left n bits. You can use the Programmer view of the Windows Calculator or locate one on the web. In Programmers view
For 32-bit fraction with decimal selected, enter: 1, Lsh, 32, =
Result: 4294967296 (decimal), 100000000000000000000000000000000 (binary)
Enter (in decimal mode): /, 9, =
Result: 477218588 (decimal), 00011100011100011100011100011100 (binary)
Insert "." 32 places to left of right most bit: .00011100011100011100011100011100
0.00011100011100011100011100011100
As how to represent this in "floating point format", you will have to decide what format. There are many different formats that are used.
In anticipation of you asking....
15/9ths can be calculated with the Windows Calculator (32 bits)
1, Lsh, 32, *, 15, /, 9
Result: 7158278826 (decimal), 110101010101010101010101010101010 (binary)
Float decimal point 32 positions to left: 1.10101010101010101010101010101010
Jim Dempsey
Hello sir
How to add
10001110100
00011010000
00111110100
Hello sir
Which ic is used for addition
