Dear guys,
We have been trying to compile C++ code with the cross compiler on SCC. But there have been problems. We are not able to compile any C++ code, even "hello world" programs. But C programs compiles and runs well.
We was able to compile c++ code on SCC in Intel. We are wondering if there is any trick in setting up the environment so that we can compile C++ code for SCC.
Yubei
Hi Jennifer,
Thanks for your reply. I have tried that recipe and can only compile C++ code without templates. It seems that even the author thinks it hard to build C++ code with templates. Our proj. is full of templates and as a programming model flexibility is important, so adding a lot explicit template instantiation may not be a good way to tackle this problem...
Sincerely,
Yubei
Sincerely,
Yubei
Topic Options
