Using intel compiler, version 11.0 for linux. We are working with precompiled header options, and want to silence the following messages:
"Using precompiled header file XXX" - each time a precompiled header is used
"Creating precompiled header file XXX" - each time a precompiled heaer is created
How do you do that with icpc? Its not a warning, or a diagnostic?
Sorry that there's no public option to turn it off right now. I've submitted a bug report to the engineer team to change the msg to a remark.
Once the fix is available you can disable the msg with -diag-disable:remark.
Jennifer
