Intel® C++ Compiler
7782 Discussions
How to handle trivial precision differences with different compiler optimizations
xuzheng97
Hello All,
Recently I met some result differences when I tried to use compier options from O0 to O3.
Though theyare trvial and even can be ignored, I still want to know more clear about them.
1. one variable value is 2.468057e-18for O0 and 1.676039e-18for O3.
This variable looks very small.
I tried '-ftz/-zero/-no-bss-init' options with O3 but no any influence.
2. variable F=4867459.8367both for O0 and O3
While F-ksi=-9.31323e-10 for O0 and -1.86265e-09 for O3
All data here are double.
In my memory double stype data has 15-16 valid numbers, then F-ksi e-9 should not make sense at all.
But how to eliminate these differences from compiler site?
Thanks & Best Regards
Om_S_Intel
Could you please try the following:
Linux and Mac OS X: -fp-modelprecise
Windows: /fp:precise
If the above does not work then you may try
Linux and Mac OS X: -fp-model source
Windows: /fp:source
xuzheng97
Om Sachan,
Thanks, I forget fp-model option :-)
In fact fp-model precise worked and eliminated these difference.
To my unstandings, fp-model precise may decrease performance.
Based my upper decription, could these difference be ignored?
Om_S_Intel
Yes, the fp-model precise may decrease performance.
The error tolerance depends on the application. The application owner should know better.
mecej4
Black Belt
Quoting xuzheng97
"Small" compared to what? 1 ? How about compared to 0 ? The diameter of an electron in light-years ?
... then F-ksi e-9 should not make sense at all.
We have no idea what "F-ksi" is; therefore, any judgements about its value making sense are premature.
You cannot, except in a contrived and pointless way. You would benefit by reading books and articles about what to expect from finite-precision calculations. For starters, Google "perfidious polynomial" and read some of the articles related to that.
