My problem is not to have a serialnumber of the Fortran-Compiler 9.1.052 and C++-Compiler 9.1.052 I'd like to install.
How can I get it?
Thank you in advance
Angela
How can I get it?
Angela
Angela,
Not sure about your request. It sounds like you want to install an older Fortran Compiler 9.1, but it failed with a license error. Did you use serial numbers for remote activation or did you use license files for 9.1 installation or are you just unsure what to do?
Pls. specify the problem. Thanks.
Regards, Hubert.
Regards, Hubert.
Topic Options
