Hello, developers
I am writing to ask some question related installing Parallel studio especially C++ compiler.
To avoid creating shared library(*.so, *.so.*), I was finding some install options to create static library only.
(In GNU compiler, disable-shared & enable-static is works)
But I could not find the similar options during installing C++ comiler via install.sh or install_GUI.sh
Please let me know the option I have found and how to apply.
Thank you all.
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Could you try using -static(Prevents linking with shared libraries), -static-intel(Causes Intel-provided libraries to be linked in statically) flags and let us know if it helps?
For more information, please refer to: https://software.intel.com/en-us/cpp-compiler-developer-guide-and-reference-linking-or-linker-options.
--Rahul
Hi Rahul,
First of all, thank you for your help.
I think you mean the compile options static and static-intel. But what I am trying to find is an installing option to install parallel studio statically.
I know that is not normal, but our system policy recommand to use static library as possible.
Or if your intention is correct to what I mean, where would I state the -static option before install.sh?
Thank you all
Kihang
I don't think we have such options. All the options are provided when you run the install script.
Let us know if this is still an issue. Otherwise, we will close it.
We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thank
