#include <stdio.h>
void mat_mul2(int M, int N, int K, double A[M][K], double B[K][N], double C[M][N])
for (int i = 0; i < M; i++) {
for (int j = 0; j < N; j++) {
for (int k = 0; k < K; k++) {
C[i][j] += A[i][k] * B[k][j];
int main(int argc, char **argv)
double A[3][3], B[3][3];
double C[3][3] = { 0 };
for (int i = 0; i < 3; i++) {
B[i][i] = 1;
for (int j = 0; j < 3; j++) {
A[i][j] = 3 * i + j;
printf("before\n");
printf(" %lf", C[i][j]);
printf("\n");
mat_mul2(3, 3, 3, A, B, C);
printf("after\n");
printf("\n");
return 0;
When I build by using above source code the output is below.
Expected results are
How can I solve this problem??
Actually It works in GCC compiler.
Could you please provide us the compiler command you have used to investigate more on your issue?
Could you also provide the Intel C compiler version you are using?
We are able to execute the mat_mul program using icl in Windows and ICC in Linux machines. Please refer to the below attachments for more information.
Thanks & Regards
Shivani
As we didn't hear back from you, Is your issue resolved? If not, please provide the details that have been asked in my previous post.
Thanks & Regards,
Shivani
As we have not heard back from you, we are considering that your issue has been resolved. So we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Shivani
