The library files are being compiled with :
[bash]-fPIC -fvisibility=hidden -fvisibility-inlines-hidden -ffunction-sections -fdata-sections [/bash] and linked with :
[bash]-static-libgcc -ldl -Wl,--gc-sections[/bash] The problem is the library size blow up to a amazing 17MB, without the above settings it's 28MB.. If I do a strip on the library afterwards, we get down in about 13-14MB, which is still too much. Looking at the output of nm it seems the hidding does not work properly, since it's exporting a large number of functions still.
With exact the same settings I can get 5.5MB after strip with gcc and 9MB before strip.
Even if I compile with intel and link with gcc directly, then the problem persists.
What settings do I need to set for intel to remove all the redudancy ?
ipo sometimes can reduce the size, and sometimes may increase the size.
The problem is that it exports a huge number of functions, which is not marked to be exported.
I think you need to review a couple of cases when some functions, declared as non-exported, are included in
a binary file of the shared library. I would consider cases:
1. If some 'FunctionA' is declared as inline, has implementation in a header file, and called at least
once in your codes onlythenithas to be included in a binary file ( this is expected result )
2.If some 'FunctionB' is declared as inline, has implementation in a header file, and not called at all in
any codes then it doesn't have to be included in a binary file ( this is expected result ).If it is included
then it looks like there is a problem with a C/C++ compiler.
The Boost is a huge template library andasimpleC++ templates-based test-case that uses atest shared
library, with some set offunctions declared differently,could helpto understand the problem.
May consider that make some other library dynamic link.
ps: in general, the size icc generated is larger than gcc.
Try to use this as an example :
[bash]#include
32053 2012-03-29 09:57 t_gcc_ia32.so
30388 2012-03-29 09:56 t_icc_ia32.so
43273 2012-03-29 09:51 t_gcc_x64.so
15513 2012-03-29 09:50 t_icc_x64.so
cmd used is from your posting with "-fPIC": icpc -fPIC -shared t.cpp -fvisibility=hidden -fvisibility-inlines-hidden -ffunction-sections -fdata-sections -Wl,--gc-sections -o t.so
So I might have missed something. Please let me know if the above is the what you have. We'd like to improve the code size issue if possible.
Jennifer
I might not have explained it clear enough, but above example is just a small one illustrating that exports end up in the library, which is not intended and most certainly different from gcc. So I was not argumenting on library size on this example only the exports. I think what goes on for my large library is that soo many functions get's exported, which makes the linker command --gc-section useless, since it can not tell which ones are not needed. Since my code is huge, I thought starting with having similar exported function like gcc was a good starting point. Try to run nm test.so | grep " T " on your two libraries.
I see.
With the "grep" cmd, I did see the big difference in the symbols being exported.
Let me file a bug to the compiler about this issue, but I'm not sure how likely it can be addressed in the current release though.
thanks,
Jennifer
This issue has been fixed in the latest update 11.
You can download the update 11 from Intel Registration Center.
Jennifer
