Intel® C++ Compiler
7783 Discussions
How to solve the problem of "PATH environment variable size has exceeded its limit."
Feng__Zemin
Dear all
When I install C++ on my computer, there are the problem of path variables"
Installation cannot continue because the length of your path is too long.
 Suggestion: Exit the installation, eliminate unnecessary items in the PATH environment variable (you need to free more than 798 symbols) using Control Panel > System and Security > System > Advanced system settings > Advanced > Environment Variables and launch the installation again.
Could you tell me how can i solve it?
Thank you very much.
Zemin
Viet_H_Intel
Hi Zemin,
Have you tried the suggestion?
Viet
jimdempseyatthecove
Black Belt
Check for (and eliminate) duplicate entries in environment variables:
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\\Intel\Licenses;C:\Progra
m Files (x86)\Common Files\Intel\Licenses
The above in an an example of the Licenses folder listed twice.
Remove old items no longer used:
INSPECTOR_2017_DIR=C:\Program Files (x86)\IntelSWTools\Inspector 2017\
INSPECTOR_XE_2013_DIR=C:\Program Files (x86)\Intel\Inspector XE 2013\
INSPECTOR_XE_2015_DIR=C:\Program Files (x86)\Intel\Inspector XE 2015\
For the above 2013 and 2015 versions no longer installed (I haven't cleaned this up yet). Use:
    Start | System | Change Settings | Advanced | Environment Variables
(the above is for Window 7, Windows 10 may have a slightly different route to reach the Environment Variables property page.
Jim Dempsey
Feng__Zemin
Dear Jim Dempsey
I didnot found the file  on my computer. The error showed that it needs more than 798 symbols of PATH, if i install any other program, it works well.
So i can not resolve it follow your suggesstion.
Zemin
