Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7695 Discussions
How to un-install intel compiler on Mac OSX
jdictos
I have the Intel compiler, version 11.0, installed on my mac, and I was wondering how I un-install it. There's no icon or anything to "drag" away.
Om_S_Intel
You may use "uninstall" program from command window to remove the compiler. In my installation this located as given below:
$ ls -l /opt/Intel/Compiler/11.0/059/uninstall
You need to be super user to run this program.
Quoc-An_L_Intel
if you have sudo privilege, you should be able to uninstall the software as Om indicated.
