I have installed the compiler and the mpss for the xeno phi. From this post: https://software.intel.com/en-us/forums/intel-many-integrated-core/topic/741289 it says I need to use compiler 17. Is that availbe in the most recent Parallel Studio Verison I installed?
If so, where is it located/how do I get access to icpc?
If not, how do I get the correct compiler?
Thanks!
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
What Intel compiler version you have installed?
You can try https://software.intel.com/en-us/intel-sdp-home
I have "icpc version 19.0.2.187" installed, but it doesn't have the compiler flag (-mmic) for the xeno phi x100 series I have. I installed it from the latest version of Parallel Studio XE found on that link.
I looked at that link, but I could not clearly see how to get an icpc version = 17. Is there a way to see the versions on the website?
Thanks for the quick response.
Have you registered for https://registrationcenter.intel.com/? If you had, then when you log in, you would be able to see 2017 versions.
Hi Viet, I logged in and found it after registering. Thanks!
