I would like to use Qt ver 4.7-beta1 with Intel C++ Compiler ver 11 that I have just downloaded. I run the Intel Compiler's "C++ Build Environment for applications running on IA-32" from Windows XP start menu and it bring up a command prompt with all the environment variables. Then I goto Qt folder and run "configure -platform win32-icc" and it started well but then encountered an error of "stddef.h file not found". I do not have Visual Studio nor Visual C++ installed in my system.
Can anyone advice how to use Qt 4.7 with Intel Compiler? Thanks in advance.
Yong Khun
Yong Khun
ICL depends on the MSVC installation to supply headers, linker, and libraries. In 32-bit mode, VC express may be sufficient for command line operation with manual editing of icl.cfg and iclvars.bat. The general advice is to install the compiler in a supported manner.
Sorry I missed this earlier. Tim is right that you need to have MSVC++ installed on Windows to use the Intel compiler. You might try MS express edition (http://www.microsoft.com/express/windows/ ). This would enable you to use the Intel compiler on the command line. I haven't tried it myself, but I expect that would enable you to use Qt with icl. I have successfully used Qt 4.6 with icc on Linux, and I've been meaning to try it on Windows. If I do that, I'll let you know what I find.
Thanks!
Dale
