Hi everyone,
How to check whether the value is loaded into the xmm register in C ??I am using GCC. For eg,
typedef struct
int val[4];
}state;
int main()
int *m;
state a;
asm(" movups (%eax),%xmm0:"=r"(m):"r"(a.val);
Here i am not able to print the m value. I need help in this issue. Thank you in advance.
typedef struct
int val[4];
}state;
int main()
int *m;
state a;
Well if you tell the CPU to load a value to XMM register it will do it or die trying. Perhaps you meant to ask how to check the loaded value from the XMM register? The only way is to write it back to memory and print it out using traditional C or C++ code.
Topic Options
