I have a compliacted C and C++ code with heavy mathematics calculations. I use intel C++ - the latest update to compile. I use optimizatons and the application does not give the expected answer. After a long time I managed to reduce the problem to getting EXCEPTION_FLT_STACK_CHECK
0xc0000092. If I compile without optimization - The program work as expected.
It's a single threaded code on Winxp64 (the application is 32-bit).
MSVC 2010 gives the same results with Debug or Release builds. (I mean Good=Expected results)
Can someone help me where to look? Currently I suspect a compiler bug - since I have no asmsembly code of my own, Only compiler-generated code. I looked at the assembler and it's SSE/x87 mixed code.
I'm looking for directions to look for. Since I'm on trial version (of the intel compiler) I don't have much time for investigations.
I will try to use /Qfp-stack-check tommorow to see if i can find something wrong with my code.
mordy.
