Hi, I'm hitting on crashes ( SEGV ) using ICC 12 and with auto-vectorized code .Auto-vectorization kicks in at -O2 or higher level optimizations . There are documented flag's to disable it ( -no-vec / -no-simd ) , but strangely I don't see ICC honouring it.The typical constructs where we see the SIMD code getting generated is for array / structure initializations. For example : char xfilePath[KPUXAXFILEPATHLENMAX] = {0};
Mostly during memset/memcpy and during initializations . Below is the assembly snippet :
(gdb) disass 0x402d1edd
Dump of assembler code for function kpuxaGlbClientAttrsInit:
0x402d1ec0 : xchg %ax,%ax
0x402d1ec2 : push %ebp
0x402d1ec3 : mov %esp,%ebp
0x402d1ec5 : sub $0x2a8,%esp
0x402d1ecb : mov $0x200,%eax
0x402d1ed0 : mov %ebx,-0xc(%ebp)
0x402d1ed3 : pxor %xmm0,%xmm0
0x402d1ed7 : mov %edi,-0x8(%ebp)
0x402d1eda : mov %esi,-0x4(%ebp)
=> 0x402d1edd : movaps %xmm0,-0x248(%ebp,%eax,1)
0x402d1ee5 : movaps %xmm0,-0x258(%ebp,%eax,1)
0x402d1eed : movaps %xmm0,-0x268(%ebp,%eax,1)
0x402d1ef5 : movaps %xmm0,-0x278(%ebp,%eax,1)
0x402d1efd : sub $0x40,%eax
movaps %xmm0,-0x248(%ebp,%eax,1) --> load from address ebp + (eax*1) - 0x248
(gdb) p $ebp+$eax
$5 = (void *) 0x42b41e8c
(gdb) p 0x42b41e8c-0x248
$6 = 1119099972
(gdb) p/x 0x42b41e8c-0x248
$7 = 0x42b41c44
MOVAPS moves a double quadword containing 4 packed single-precision FP values from the source operand to the destination. When the source or destination operand is a memory location, it must be aligned on a 16-byte boundary,otherwise a general protection exception (GP#) is
generated.
This address 0x42b41c44 should have been 16-byte aligned else a General Protection Exception will be raised. The problem can be thatICC 12 thinks that ebp is 16 byte aligned whereas it is 4-byte aligned as per the Intel 32-bit ABI.
The crash doesn't seem to re-produce in the below situations :1. On 64-bit Linux2. With the older version ICC compilers3. With optimization level -O1 and below
$icc -VIntel C Compiler XE for applications running on IA-32, Version 12.0 Build 20111014Copyright (C) 1985-2011 Intel Corporation. All rights reserved.Appreciate any of your comments or suggestions.
did you try with latest compiler from Intel Composer XE 2011 Update 11? If it does not occur there we high likely fixed it in the previous releases. It should be simpler to first test with the latest compiler than to reproduce the problem.
If it still fails you might provide me a more complex reproducer (via private reply). I can shrink it down to something engineering can handle. So far I failed to reproduce such a GP fault myself.
Unless you did not enforce the alignment and access to it manually (e.g. via pragma simd) I'm pretty sure it's a compiler optimization bug and we're highly interested to reproduce them on our side, too.
Regarding -no-vec vs. -no-simd:
Georg Zitzlsberger
Edit: Opposed to what I've written above, -no-simd does not disable SIMD instructions in general. Particularly, it only disables the SIMD pragmas/directives. If you want to get rid of SIMD instructions alltogether there is only the option to compile for IA32 legacy (-mia32 [Linux*] or /arch:IA32 [Windows*]). However, this does not work for OS X* because the earliest processors available there already had SSE. It also is not possible for 64 bit processors because of the same reason.
I'm taking care to update the compiler documentation to correct this.
I just got informed that a fix for the above problem is part of Intel(R) Composer XE 2013 SP1 (and higher).
Georg Zitzlsberger
