Hello!
I use the Intel compiler with Visual Studio 2012. When i try to compile your project, you receive the following error message:
TRACKER : error TRK0002: cannot execute command: "C:\Windows\system32\icl.exe @C:\Users\Андрей\AppData\Local\Temp\tmpf7a7234dcd5842f8bf4d551ecf72fa3f.rsp". Error code FileTracker: 0xc1
Thought the problem was in the way to my home directory that contains Cyrillic, but no. I created a separate user and it had the same problems with the build of the project. What could be the problem?
Thanks!
Do you have "full control" permissions and sufficient space in those \AppData\Local\Temp\ folders?
do you have VS2012 RTM? please upgrade to the latest update (update 4) and see if the problem goes away.
Jennifer
Jennifer
Jennifer
C:\>where icl C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\intel64\icl.exe C:\Windows\System32\icl.exe
And again I do not understand why in the path of the file as there is in the system32 folder. Search using the console application "FIND" gave the following:
C:\>find "icl.exe" C:\Windows\System32\
If you haven't moved any compiler folders since installing, the installed shortcut C:\Windows\SysWOW64\cmd.exe /E:ON /V:ON /K ""C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\ipsxe-comp-vars.bat" intel64 vs2012" will run the selected corresponding visual studio script as well as setting up the ICL paths. It would be preferable not to have any conflicting entries in the windows startup paths.
Yes, that's right, in the shortcut prescribed the following path:
