I use icc (ICC) version 17.0.0 (20160721). I found a bug in the way its MPX transformation pass treats code with VLAs (variable-length arrays allocated on stack). My computer has an Intel Skylake CPU (though I don't think it plays any role).
Here is the minimal test case that reproduces the problem (adapted from Dedup program where the bug was triggered):
#include <pthread.h> struct thread_args { int tid; }; void* threadfunc(void * targs) { struct thread_args *args = (struct thread_args *)targs; return (void*) args->tid; } __attribute__((noinline)) int foo(int nthreads) { int threadret=0; pthread_t threads_chunk[4]; struct thread_args chunk_thread_args[nthreads]; // VLA array! Translates into a call to __chkp_vla_alloc() // struct thread_args chunk_thread_args[4]; // THIS WORKS for (int i = 0; i < nthreads; i ++) { chunk_thread_args.tid = i; pthread_create(&threads_chunk, NULL, threadfunc, &chunk_thread_args); } for (int i = 0; i < nthreads; i ++) { pthread_join(threads_chunk, (void**)&threadret); } return threadret; } int main() { int ret = foo(1); return ret; // supposed to return `0` }
The code is supposed to return `0` but returns garbage values. The optimization level doesn't matter.
>>> icc -O0 -ggdb -check-pointers-mpx=rw -lmpx -pthread test.c >>> ./a.out >>> echo $? 112 # garbage value >>> icc -O2 -ggdb -check-pointers-mpx=rw -lmpx -pthread test.c >>> ./a.out >>> echo $? 96 # garbage value >>> icc -O2 -ggdb -pthread test.c >>> ./a.out >>> echo $? 0
So in a nutshell, whenever ICC-MPX detects a VLA stack-allocated array, it calls a function __chkp_vla_alloc(). Somehow, this corrupts the stack, so a later access to the stack-based `args->tid` reads garbage from the stack address.
Hi Dmitrii,
Let me try to reproduce it and investigate. I will escalate it in case it is a bug.
Igor
I escalated it to the engineering team (DPD200415547).
