Intel® C++ Compiler
ICC 17 and Auto Vectorization
piedpiper
I have just recently begun experimenting with ICC 17 and its auto-vectorization features.   I was wondering if anyone could explain why the following code ('blah') can be auto-vectorized by ICC while ('blahblah') cannot ?  The difference being that variables a,b,c are declared on the stack in 'blahblah'.
const int numElems = 256;
void blah(double a[], double b[], double c[])
   int i = 0;
   // This vectorizes
   for (i = 0; i < numElems; i++)
     a = b * c;
void blahblah()
   double a[numElems];
   double b[numElems];
   double c[numElems];
   int i = 0;
   // This does not vectorize
     a = b * c;
Thanks in advance for any help.
Judith_W_Intel
What makes you think the loop was not vectorized? I see the following in the optimization report:
sptxl15-274> cat t.c
void blahblah()
   double a[numElems];
   double b[numElems];
   double c[numElems];
   int i = 0;
     a = b * c;
sptxl15-275> icc -qopt-report=5 -c t.c
icc: remark #10397: optimization reports are generated in *.optrpt files in the output location
sptxl15-276> grep "LOOP" *.optrpt | grep VECTOR
   remark #15300: LOOP WAS VECTORIZED
sptxl15-277>
Are you using any special command line switches?
Judy
Judith_W_Intel
void blahblah()
   double a[numElems];
   double b[numElems];
   double c[numElems];
   int i = 0;
     a = b * c;
sptxl15-277>
Judy
piedpiper
Sorry for the confusion.  You're correct.   The loops are vectorized in both code samples - I confirmed on my test bench.
