Intel® C++ Compiler
ICC 2017 Preprocessor bug with tokens concatenation
Andrei_P_1
Hello. I'm found a bug with tokens concatenationSimple example to reproduce:
#define test(x, y) sizeof(x##y)
#define test2(x, y) sizeof(##x##y)
int main()
	int a = test(in, t); // works fine
	int b = test2(in, t); // error
Compilation on windows (msvc integration):
1>  main.cpp
1>..\main.cpp(6): error : identifier "in" is undefined
1>    	int b = test2(in, t); // error
1>    	        ^
1>
1>..\main.cpp(6): error : expected a ")"
Preprocessor output to file:
#line 1 "..\\main.cpp"
int main()
	int a = sizeof(int);
	int b = sizeof(int);
Judith_W_Intel
You are correct that we should try to emulate what Microsoft is doing, but your code is definitely incorrect according to the standard.
The GNU compiler gives this error:
sptxl15-134> g++ -c main.cpp
main.cpp:9:1: error: pasting "(" and "in" does not give a valid preprocessing token
sptxl15-135>
The token paste operator must result in a valid token and the second expansion does not have one.
https://gcc.gnu.org/onlinedocs/cpp/Concatenation.html
Andrei_P_1
Thanks for the answer. I am found it by accident, when a working project didn't builded after replacing MSVC to ICC 17. The similar code also worked with ICC for linux. So, I was thinked that it's a bug. But in fact, the work of this code is not necessary, this situation was caused by a typo when copypasting. It will be enough to display a correct error message like it does GCC.
