Hello. I'm found a bug with tokens concatenation. Simple example to reproduce:
#define test(x, y) sizeof(x##y) #define test2(x, y) sizeof(##x##y) int main() { int a = test(in, t); // works fine int b = test2(in, t); // error }
Compilation on windows (msvc integration):
1> main.cpp 1>..\main.cpp(6): error : identifier "in" is undefined 1> int b = test2(in, t); // error 1> ^ 1> 1>..\main.cpp(6): error : expected a ")" 1> int b = test2(in, t); // error
Preprocessor output to file:
#line 1 "..\\main.cpp" int main() { int a = sizeof(int); int b = sizeof(int); }
You are correct that we should try to emulate what Microsoft is doing, but your code is definitely incorrect according to the standard.
The GNU compiler gives this error:
sptxl15-134> g++ -c main.cpp
main.cpp:9:1: error: pasting "(" and "in" does not give a valid preprocessing token
sptxl15-135>
The token paste operator must result in a valid token and the second expansion does not have one.
https://gcc.gnu.org/onlinedocs/cpp/Concatenation.html
Thanks for the answer. I am found it by accident, when a working project didn't builded after replacing MSVC to ICC 17. The similar code also worked with ICC for linux. So, I was thinked that it's a bug. But in fact, the work of this code is not necessary, this situation was caused by a typo when copypasting. It will be enough to display a correct error message like it does GCC.
