Hello!
I use ICC 2019 update 5 embedded into VS2019 16.1.6. I observed something strange with std::map::insert(). I perform insertion of elements from a std::vector<int> to a std::map<int, int>, using the element value as the map key. Depending on the way I insert them or the compilation switches I use, I don't obtain the same map. See a question on StackOverflow.
Here is the code snippet I used:
#include <map> #include <vector> #include <iostream> std::map<int, int> AddToMapWithDependencyBetweenElementsInLoop(const std::vector<int>& values) { std::map<int, int> myMap; for (int i = 0; i < values.size(); i+=3) { myMap.insert(std::make_pair(values, myMap.size())); myMap.insert(std::make_pair(values[i + 1], myMap.size())); myMap.insert(std::make_pair(values[i + 2], myMap.size())); } return myMap; } std::map<int, int> AddToMapOnePerLoop(const std::vector<int>& values) { std::map<int, int> myMap; for (int i = 0; i < values.size(); ++i) { myMap.insert(std::make_pair(values, 0)); } return myMap; } int main() { std::vector<int> values{ 6, 7, 15, 5, 4, 12, 13, 16, 11, 10, 9, 14, 0, 1, 2, 3, 8, 17 }; { auto myMap = AddToMapWithDependencyBetweenElementsInLoop(values); for (const auto& keyValuePair : myMap) { std::cout << keyValuePair.first << ", "; } std::cout << std::endl; } { auto myMap = AddToMapOnePerLoop(values); for (const auto& keyValuePair : myMap) { std::cout << keyValuePair.first << ", "; } std::cout << std::endl; } return 0; }
If I compile using "icl mycode.cpp" and I run the program, I obtain this:
0, 1, 2, 3, 4, 5, 6, 7, 11, 12, 13, 14, 15, 16, 17,
0, 1, 2, 3, 4, 5, 6, 7, 12, 13, 14, 15, 16, 17
(I expected the same number for both lines and 18 numbers on each lines since there are 18 different numbers inserted in the map)
If I compile using "icl /EHsc mycode.cpp" and I run, I obtain:
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17,
(Again, unexpected results?)
If I compile using "icl /Od mycode.cpp" and I run:
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17,
This is the expected result...
Note that I compared using the same switches but with cl.exe (Microsoft compiler) and I always obtain the expected result.
Any idea about the case? Is it a bug? Did I do something wrong? Thanks for your help!
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
I couldn't reproduce it.
C:\temp>icl test_832619.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.5.271 Build 20190724
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
test_832619.cpp
Microsoft (R) Incremental Linker Version 14.22.27905.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:test_832619.exe
test_832619.obj
C:\temp>test_832619.exe
C:\temp>icl /EHsc test_832619.cpp
test_832619.cpp
test_832619.obj
C:\temp>
