when I compile firefox using lastest Intel C++ Compiler, I get such errors. VS2012 works fine.
../../dist/include/mozilla/dom/BindingUtils.h(1664): error: template instantiati
on resulted in unexpected function type of "char (&(char (*)[1]))[1]" (the meani
ng of a name may have changed since the template declaration -- the type of the
template is "char (&(char (*)
HAS_MEMBER(JSBindingFinalized)
detected during:
compilation aborted for d:/develop/mozilla/ICC/obj-vca/dom/bindings/AnalyserNode
Binding.cpp (code 2)
instantiation of "mozilla::dom::HasJSBindingFinalizedMember<T>::Chec
k [with T=mozilla::dom::AnalyserNode]" based on template argument <mozilla::dom:
:AnalyserNode> at line 1664
instantiation of class "mozilla::dom::HasJSBindingFinalizedMember<T>
[with T=mozilla::dom::AnalyserNode]" at line 1666
processing of template argument list for "mozilla::dom::JSBindingFin
alized" based on template argument <mozilla::dom::AnalyserNode> at line 453 of "
d:/develop/mozilla/ICC/obj-vca/dom/bindings/AnalyserNodeBinding.cpp"
two questions:
- which version of ICL do you use
- please post the cmd line (should include the .cpp).
Jennifer
My version of Firefox might be old, there is no "AnalyserNodeBinding.cpp" file.
Could you attach a .i file? Just in your cywin window, run the cmd below (added -EP -P options). thanks!
icl -c -D_HAS_EXCEPTIONS=0 -I../../dist/stl_wrappers -DMOZILLA_INTERNAL_API -D_IMPL_NS_COM -DEXPORT_XPT_API -DEXPORT_XPTC_API -D_IMPL_NS_GFX -D_IMPL_NS_WIDGET -DIMPL_XREAPI -DIMPL_NS_NET -DIMPL_THEBES -DNO_NSPR_10_SUPPORT -DEXCLUDE_SKIA_DEPENDENCIES -DUNICODE -D_UNICODE -DNOMINMAX -D_CRT_RAND_S -DCERT_CHAIN_PARA_HAS_EXTRA_FIELDS -D_SECURE_ATL -DCHROMIUM_BUILD -DU_STATIC_IMPLEMENTATION -DOS_WIN=1 -DWIN32 -D_WIN32 -D_WINDOWS -DWIN32_LEAN_AND_MEAN -DCOMPILER_MSVC -D_IMPL_NS_LAYOUT -Id:/develop/mozilla/ICC/ipc/chromium/src -Id:/develop/mozilla/ICC/ipc/glue -I../../ipc/ipdl/_ipdlheaders -Id:/develop/mozilla/ICC/dom/base -Id:/develop/mozilla/ICC/dom/battery -Id:/develop/mozilla/ICC/dom/encoding -Id:/develop/mozilla/ICC/dom/file -Id:/develop/mozilla/ICC/dom/power -Id:/develop/mozilla/ICC/dom/push -Id:/develop/mozilla/ICC/dom/quota -Id:/develop/mozilla/ICC/dom/media -Id:/develop/mozilla/ICC/dom/network/src -Id:/develop/mozilla/ICC/dom/phonenumberutils -Id:/develop/mozilla/ICC/dom/alarm -Id:/develop/mozilla/ICC/dom/src/events -Id:/develop/mozilla/ICC/dom/src/storage -Id:/develop/mozilla/ICC/dom/src/offline -Id:/develop/mozilla/ICC/dom/src/geolocation -Id:/develop/mozilla/ICC/dom/src/notification -Id:/develop/mozilla/ICC/dom/workers -Id:/develop/mozilla/ICC/dom/time -Id:/develop/mozilla/ICC/content/xbl/src -Id:/develop/mozilla/ICC/content/xul/document/src -Id:/develop/mozilla/ICC/content/events/src -Id:/develop/mozilla/ICC/content/base/src -Id:/develop/mozilla/ICC/content/html/content/src -Id:/develop/mozilla/ICC/content/html/document/src -Id:/develop/mozilla/ICC/content/media/webaudio -Id:/develop/mozilla/ICC/content/svg/content/src -Id:/develop/mozilla/ICC/layout/generic -Id:/develop/mozilla/ICC/layout/style -Id:/develop/mozilla/ICC/layout/xul/base/src -Id:/develop/mozilla/ICC/layout/xul/tree -Id:/develop/mozilla/ICC/dom/camera -Id:/develop/mozilla/ICC/content/media/webspeech -Id:/develop/mozilla/ICC/js/xpconnect/src -Id:/develop/mozilla/ICC/js/xpconnect/wrappers -Id:/develop/mozilla/ICC/content/canvas/src -Id:/develop/mozilla/ICC/content/html/content/src -Id:/develop/mozilla/ICC/media/webrtc/signaling/src/peerconnection -Id:/develop/mozilla/ICC/dom/base -Id:/develop/mozilla/ICC/dom/battery -Id:/develop/mozilla/ICC/dom/indexedDB -Id:/develop/mozilla/ICC/content/xslt/src/base -Id:/develop/mozilla/ICC/content/xslt/src/xpath -Id:/develop/mozilla/ICC/content/xml/content/src -Id:/develop/mozilla/ICC/content/xul/content/src -Id:/develop/mozilla/ICC/content/xul/document/src -Id:/develop/mozilla/ICC/content/media/webspeech/recognition -Id:/develop/mozilla/ICC/dom/bindings -I. -I../../dist/include -Id:/develop/mozilla/ICC/obj-vca/dist/include/nspr -Id:/develop/mozilla/ICC/obj-vca/dist/include/nss -wd4099 -TP -nologo -w -Gy -Fdgenerated.pdb -wd4251 -wd4244 -wd4345 -wd4351 -wd4482 -wd4800 -wd4819 -we4553 -GR- -DNDEBUG -DTRIMMED -Oy- -MD -FI ../../dist/include/mozilla-config.h -DMOZILLA_CLIENT -EP -P d:/develop/mozilla/ICC/obj-vca/dom/bindings/AnalyserNodeBinding.cpp
Folin J. wrote:
AnalyserNodeBinding.zip
Thanks for attaching the file. which VC do you use? is it building this file ok? I got some errors from VC2010.
Jennifer
VC's error msg:
D:\Jennifer\Issues\U390553>cl /c /Od /Zc:forScope,auto,trigraphs /TP AnalyserNodeBinding.i
Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 16.00.40219.01 for 80x86
Copyright (C) Microsoft Corporation. All rights reserved.AnalyserNodeBinding.i
AnalyserNodeBinding.i(9637) : error C2275: '_Ty' : illegal use of this type as an expression
AnalyserNodeBinding.i(9639) : see reference to class template instantiation 'std::is_standard_layout<_Ty>' being
compiled
AnalyserNodeBinding.i(9637) : error C3861: '__is_standard_layout': identifier not found
AnalyserNodeBinding.i(9638) : error C2955: 'std::_Cat_base' : use of class template requires template argument list
AnalyserNodeBinding.i(5709) : see declaration of 'std::_Cat_base'
AnalyserNodeBinding.i(9643) : error C2275: '_Ty' : illegal use of this type as an expression
AnalyserNodeBinding.i(9645) : see reference to class template instantiation 'std::is_literal_type<_Ty>' being co
mpiled
AnalyserNodeBinding.i(9643) : error C3861: '__is_literal_type': identifier not found
AnalyserNodeBinding.i(9644) : error C2955: 'std::_Cat_base' : use of class template requires template argument list
AnalyserNodeBinding.i(9649) : error C2275: '_Ty' : illegal use of this type as an expression
AnalyserNodeBinding.i(9651) : see reference to class template instantiation 'std::is_trivial<_Ty>' being compile
d
AnalyserNodeBinding.i(9649) : error C3861: '__is_trivial': identifier not found
AnalyserNodeBinding.i(9650) : error C2955: 'std::_Cat_base' : use of class template requires template argument list
AnalyserNodeBinding.i(9814) : warning C4346: 'std::is_array<_Ty>::value' : dependent name is not a type
prefix with 'typename' to indicate a type
AnalyserNodeBinding.i(9817) : see reference to class template instantiation 'std::is_trivially_constructible<_Ty
,_Ty,std::_Nil,std::_Nil,std::_Nil,std::_Nil,std::_Nil,std::_Nil,std::_Nil>' being compiled
AnalyserNodeBinding.i(9814) : error C2144: syntax error : 'std::remove_reference<_Ty>::type' should be preceded by ')'
AnalyserNodeBinding.i(9814) : error C3861: '__is_trivially_copyable': identifier not found
AnalyserNodeBinding.i(9816) : error C2143: syntax error : missing ';' before '{'
AnalyserNodeBinding.i(9817) : error C2143: syntax error : missing ';' before '}'
AnalyserNodeBinding.i(9817) : fatal error C1004: unexpected end-of-file found
Jennifer J. (Intel) wrote:I use vs2012. It works fine. mozilla building system will deal with some macro to use different compiler, for example the C++11 .Quote:
Folin J. wrote:AnalyserNodeBinding.zip
Jennifer
