Intel® C++ Compiler
7956 Discussions
ICC can't build Firefox 12b2 on Windows
xunxun
I use ICC 12.1.300
When compiling Factory.cpp, it will cause
[bash]make[6]: Entering directory `/e/Mozilla/beta-build/obju-icc/gfx/2d' Factory.cpp icl -FoFactory.obj -c -D_HAS_EXCEPTIONS=0 -I../../dist/stl_wrappers -DMOZ_GFX -DUSE_CAIRO -DSK_A32_SHIFT=24 -DSK_R32_SHIFT=16 -DSK_G32_SHIFT=8 -DSK_B32_SHIFT=0 -DWIN32 -DMOZILLA_INTERNAL_API -D_IMPL_NS_COM -DEXPORT_XPT_API -DEXPORT_XPTC_API -D_IMPL_NS_GFX -D_IMPL_NS_WIDGET -DIMPL_XREAPI -DIMPL_NS_NET -DIMPL_THEBES -DOSTYPE=\"WINNT6.1\" -DOSARCH=WINNT -I/e/Mozilla/beta-build/mozilla-beta/gfx/2d -I. -I../../dist/include -I../../dist/include/nsprpub -Ie:/Mozilla/beta-build/obju-icc/dist/include/nspr -Ie:/Mozilla/beta-build/obju-icc/dist/include/nss -TP -nologo -W3 -Gy -Fdgenerated.pdb -wd4800 -we4553 -DNDEBUG -DTRIMMED -O2 -Oy -Ie:/Mozilla/beta-build/obju-icc/dist/include/cairo -MD -FI ../../dist/include/mozilla-config.h -DMOZILLA_CLIENT /e/Mozilla/beta-build/mozilla-beta/gfx/2d/Factory.cpp Factory.cpp e:\Mozilla\beta-build\obju-icc\dist\include\nsExpirationTracker.h(321): error: expected a ";" class ExpirationTrackerObserver MOZ_FINAL : public nsIObserver { ^ detected during instantiation of class "nsExpirationTracker [with T=gfxFont, K=3U]" at line 690 of "e:\Mozilla\beta-build\obju-icc\dist\include\gfxFont.h" compilation aborted for e:/Mozilla/beta-build/mozilla-beta/gfx/2d/Factory.cpp (code 2) make[6]: *** [Factory.obj] Error 2
[/bash]
The generated Preprocessed source files you can download here
http://pcxfirefox.googlecode.com/files/cpp.7z
VC can build the source code. Is this a ICC bug or Firefox code issue?
Brandon_H_Intel
It looks like a compatibility issue with Microsoft's compiler. I have submitted a problem report to our front-end team on it, and I'll update the thread when they make progress on their investigation.
IDZ_A_Intel
Thank you, Brandon.
I'll be waiting.
xunxun
I am sure ICC 12 update 10 has fixed the issue, but someone said there is also the problem in ICC 13.
Brandon_H_Intel
I've confirmed that this is resolved in C++ Composer XE 2011 update 10 and in the beta update 1 of the 2013 beta if you're interested in that.
Alex_K_6
I was having the same issue but it does seem to be resolved now, great work!
xunxun
btw,
ICC13.0.0.027 is the update1 of ICC13 (don't know update1 link)?
I use the edition to build ff13b5
it will cause
ipc_sync_channel.cc
e:/Mozilla/beta/mozilla-beta/ipc/chromium/src/chrome/common/ipc_sync_channel.cc(321): internal error: assertion failed at: "shared/cfe/edgcpfe/statements.c", line5830
compilation aborted for e:/Mozilla/beta/mozilla-beta/ipc/chromium/src/chrome/common/ipc_sync_channel.cc (code4)
xunxun
I entered the link
http://software.intel.com/en-us/forums/showthread.php?t=104796&o=a&s=lr
But only find Intel Parallel Studio XE 2013 beta dowload link.
Can't find Intel C++ Composer XE 2013 beta update1 ... :(
TimP
Beta update 1 was retired. Beta compilers can be obtained individually within the Parallel Studio beta.
Problem reports on beta compilers should be filed during the term of the beta test in the beta test category on premier.intel.com. One expects they don't have enough lasting validity or general interest to be discussed on the forum.
xunxun
Quoting TimP (Intel)
I will report the bug.
