The following code is failing on ICC 18.0.3, while it works fine on gcc 4.8.5, clang 3.4.2, MS Visual Studio 2017:
- file.h
template<typename HeadNodeType> static void addFetaCoefficientsForHeadNodes( HeadNodeType const &headNode, Path const &path, std::string const &attributeName, Coefficients const &coeffs, FetaTuplesMap<HeadNodeType, Path> &fetaHeadNodeMap);
- file_impl.h (Implementation is made in a separate header file to keep the main header cleaner)
template<typename HeadNodeType> void Objective::addFetaCoefficientsForHeadNodes( HeadNodeType const &headNode, Path const &path, std::string const &attributeName, Coefficients const &coeffs, FetaTuplesMap<HeadNodeType, Path> &fetaHeadNodeMap)
- file.cpp (using the previous)
void Objective::addFetaCoefficients( SourceNode const &sourceNode, Path const &path, std::string const &attributeName, Coefficients const &coeffs) { addFetaCoefficientsForHeadNodes(sourceNode, path, attributeName, coeffs, m_fetaSourceNodeMap); }
void Objective::addFetaCoefficients( StockpileNode const &stockpileNode, Path const &path, std::string const &attributeName, Coefficients const &coeffs) { addFetaCoefficientsForHeadNodes(stockpileNode, path, attributeName, coeffs, m_fetaStockpileNodeMap); }
The issue is:
file.cpp(31): error: no instance of function template "Objective::addFetaCoefficientsForHeadNodes" matches the argument list
argument types are: (const SourceNode, const Path, const std::string, const Coefficients, FetaMapSourceNode)
file_impl.h(16): note: this candidate was rejected because at least one template argument could not be deduced
As explained, this works fine on any other of the named compilers. It doesn't even work by expliciting the types in the functions calls in the cpp file, as:
addFetaCoefficientsForHeadNodes<SourceNode>(sourceNode, path, attributeName, coeffs, m_fetaSourceNodeMap); ... addFetaCoefficientsForHeadNodes<StockpileNode>(stockpileNode, path, attributeName, coeffs, m_fetaStockpileNodeMap);
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you please provide your command line options and show us how to compile your test case?
Viet
The command line used to compile is this:
/opt/intel/compilers_and_libraries/linux/bin/intel64/icc -I/usr/local/include -I/home/apalma/MinePlanner/CMPicc/OPP/include -I/opt/ibm/ILOG/CPLEX_Studio128/cplex/include/ilcplex -I/opt/gurobi801/linux64/include -fmax-errors=1 -Wextra -march=native -std=c++11 -DTIMING -pedantic-errors -Wall -Werror -O3 -DNDEBUG -s -fPIC -o CMakeFiles/opp_static.dir/opp_objective.cpp.o -c /home/apalma/MinePlanner/CMPicc/OPP/src/opp_objective.cpp
Can you provide us a complete test case? I am having other compilation issues with those files you provided on Friday.
Or you can give us a preprocess file by running the below command:
/opt/intel/compilers_and_libraries/linux/bin/intel64/icc -I/usr/local/include -I/home/apalma/MinePlanner/CMPicc/OPP/include -I/opt/ibm/ILOG/CPLEX_Studio128/cplex/include/ilcplex -I/opt/gurobi801/linux64/include -fmax-errors=1 -Wextra -march=native -std=c++11 -DTIMING -pedantic-errors -Wall -Werror -O3 -DNDEBUG -fPIC -E /home/apalma/MinePlanner/CMPicc/OPP/src/opp_objective.cpp >& testcase.i
Viet
