I've hit an error while building one of my windows DLL projects using ICC. The DLL builds fine with VC. When I switch to using Intel C++ (16.0) and try building, I get the following error:
1> Building with Intel(R) C++ Compiler 16.0
1>ClCompile:
1> ***** ClCompile (x64 - Intel C++)
1>C:\\Program Files (x86)\\MSBuild\\Microsoft.Cpp\\v4.0\\V110\\Platforms\\x64\\PlatformToolsets\\Intel C++ Compiler 16.0\\Microsoft.Cpp.x64.Intel C++ Compiler 16.0.targets(230,5): error MSB6006: "icl.exe" exited with code -1073741819.
1>
1>Build FAILED.
ICC is installed fine, and it has no problem building other projects. The problematic project is pure C++.
I have also raised this via Premier support but I haven't had a response. Any clues?
Hi can you give me the IPS ticket number for this ?
I will take a look at it.
Kenneth
Hello Kenneth
It's 6000133082.
Hi Kannan,
I looked at the issue in Premier Support and Anoop has responded to you asking your input. Could you please communicate to Anoop via that issue towards resolution? Appreciate much for your help. We can then update this thread upon resolution as well, thanks
_Kittur
Hi Kittur
This seems to have gone quiet again, I sent a bunch of code that I was asked for.
Hi Kannan,
Yes, I've pinged Anoop who's handling your issue in Premier Support to respond to you right away. Appreciate your patience. (Ken - fyi).
_Kittur
Hi Kannan,
Sorry about the delay in response. I checked the files you provided but unfortunately it has some missing pieces which is stopping me from reproducing the error you see on your end. I have provided more information on IPS for your reference.
Thanks and Regards
Anoop
