Intel® C++ Compiler
7956 Discussions
ICC failed some tests from Monocypher crypto library
P__Mike
hi all, https://monocypher.org/ https://github.com/LoupVaillant/Monocypher Monocypher is unique one file crypto library. It already compiles and passed tests on different compilers and platforms: gcc, clang, pcc, cproc, tcc, "Oracle Developer studio", "IBM XL C". Also it passing TIS and CompCert (both interpreter mode) and runtime SANs from gcc-clang family. ICC failed on *some* tests from library test suite. My Ubuntu 18.04.4 LTS, x64 environment: $ uname -a Linux ubuntu 5.3.0-46-generic #38~18.04.1-Ubuntu SMP Tue Mar 31 04:17:56 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux $ icc -v icc version 19.1.1.219 (gcc version 7.5.0 compatibility) How to repeat: $ wget https://monocypher.org/download/monocypher-3.1.0.tar.gz $ tar zxvf monocypher-3.1.0.tar.gz $ cd monocypher-3.1.0/ $ make test // all lines starting with "OK" // "All tests OK!" as last line of output $ make clean $ make test CC=icc // three FAILED tests: // FAILED 48 tests: poly1305 // FAILED 320 tests: aead_ietf // FAILED: Poly1305 (incremental)
RahulV_intel
Hi Mike,
You are right. 3 tests are failing with monocypher-3.1.0 version. But with 3.0.0 version, I don't see any issue. Thanks for reporting this, we will let the concerned team know about this issue.
--Rahul
P__Mike
Vaidya, Rahul (Intel) wrote:
Hi Mike,
--Rahul
Feel free open issue on github. Looking forward to hearing from you soon.
Thanks a lot.
Viet_H_Intel
Looks like a bug in the compiler. I've reported it to our Developer.
Viet_H_Intel
Hi Mike,
This issue is fixed in oneAPI HPC 2021.2 toolkit. Please test this compiler out and let us know so that we can close this thread.
ArpitaP_Intel
Hi Mike,
We assume that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored
Arpita
