Intel® C++ Compiler
ICC fails in link but G++ can link
joshi__himanshu
Simple hello world program(bottom of post) when I try to compile & link using ICC:
hmbp:nnCPPProf hima$ icpc -o test test.cpp
Undefined symbols for architecture x86_64:
  "__ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEEC1Emc", referenced from:
      _main in icpcIBtuRJ.o
ld: symbol(s) not found for architecture x86_64
but g++ can do it:
hmbp:nnCPPProf hima$ g++ -o test test.cpp
hmbp:nnCPPProf hima$ ./test
Hello World.
The program:
hmbp:nnCPPProf hima$ cat test.cpp
#include <iostream>
using namespace std;
int main(int argc, const char* argv[])
  cout<<"Hello World."<<endl;
  return 0;
I am missing some kind of setup but I ran the setup script suggested by the installer and still no difference.
Viet_H_Intel
what ICC version are you using? And also what OS? It definitely has something to do with your missing setup.
joshi__himanshu
hmbp:~ hima$ icc --version
icc (ICC) 19.0.5.281 20190816
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
On OSX Mojave: 10.14.6 (18G1012)
Viet_H_Intel
Seems like you are using the OS that released (October 29, 2019) after the compiler released (August 16, 2019)
And what is your Xcode version?
John_G_8
This is exactly the same problem I reported on 11/26, under Forum heading "Update for Forum topic: icpc totally broken Apple". Almost the same test program too.
joshi__himanshu
Viet, here is my xcode version:
hmbp:src hima$ /usr/bin/xcodebuild -version
Xcode 11.2.1
Build version 11B500
I am still facing this problem.
John: Were you able to figure out what is happening? Did you resolve the issue?
Viet_H_Intel
Since we weren't able to test any OS/Xcode versions which released after the compiler released date, you may run into some issues.
Is it possible for you to use over OS/Xcode versions? or wait for the next compiler version.
Viet_H_Intel
typo: over=older
John_G_8
The problem is that Intel can't keep up with Apple Xcode releases. My security plan requires we use the latest version. I think it may be possible to revert to an older version of Xcode and this might get icpc working again.  My likely solution will be to no longer purchase the Intel compiler for my Apple computers as I am getting very little utility out of them due to issues of this type. In case you care, Macports GCC is broken for a similar reason, namely Apple no longer installs headers and libraries in standard places. Fortunately GCC provides a compile line workaround via the --sysroot option, e.g.
g++ --sysroot /Library/Developer/CommandLineTools/SDKs/MacOSX.sdk hello.cc
that works around this problem
while icc and icpc also have a --sysroot option, it doesn't fix this problem. For g++ the issue was that it couldn't find the header files and using --sysroot allowed these to be located. For icpc the headers seem to be found, but not relevant dynamic or static libraries needed to build C++ code.
