Intel® C++ Compiler
ICC for new Fedora 14
qtl
I upgraded my desktop to Fedora 14 today. Then my programs written for icc can not run.
  1. programs with #include can't be compiled by icc, g++ is fine
    solution: copy old version of iomanip to local directory, and change code to #include"iomanip"
  2. programs are not allowed to run MKL libraries.
    solution: $chcon -t execmem_exec_t a.out
These are just some temporary solutions. It's tedious to do this everytime. I wonder if there's some better solutions.
Kittur_G_Intel
No, we don'tofficially support FC14 yet as it's just released this week. But in general,the problems would be with the newer gcc version and orheader files etc.
If you can attach a specific test case or if you wantus to look into certain specific issues to resolve, please do so and I can pass it on to our developers so they can suggest workarounds etc. Basically, they will need specifics of the issues.
Also, I'll let you know as soon as the release with official support for FC14 is out.
_Cheers,
Kittur
qtl
==============================1st problem==============================
The codes can be as simple as below:
[cpp]#include
#include
using namespace std;
int main(int argc, char*argv[])
  cout< then compile it with icc got the followint results
/usr/include/c++/4.5.1/iomanip(64): error: expected an expression
{ return { __mask }; }
/usr/include/c++/4.5.1/iomanip(94): error: expected an expression
/usr/include/c++/4.5.1/iomanip(125): error: expected an expression
{ return { __base }; }
/usr/include/c++/4.5.1/iomanip(193): error: expected an expression
{ return { __n }; }
/usr/include/c++/4.5.1/iomanip(223): error: expected an expression
{ return { __n }; }
compilation aborted for t.cpp (code 2)
==============================2nd problem==============================
[cpp]#include
#include
#include
int main(int argc, char *argv[])
  if(argc==1) return 1;
  int dim(atoi(argv[1]));
  if(dim<10)  return 2;
  int len(dim*dim);
  double *ori, *inv, *work;
  int    *ipiv, lwork(dim*64);
  int    i, j, seed(777), incx(1), incy(1), info;
  VSLStreamStatePtr stream;
  vslNewStream(&stream, VSL_BRNG_MT19937, seed);
  ori =new double[len];
  inv =new double[len];
  work=new double[lwork];
  ipiv=new int[dim];
  vdRngUniform(VSL_METHOD_DUNIFORM_STD, stream, len, inv, 0., 1.);
  dcopy(&len, inv, &incx, ori, &incy);  //backup the matrix
  dgetrf(&dim, &dim, inv, &dim, ipiv, &info);
  dgetri(&dim, inv, &dim, ipiv, work, &lwork, &info);
  cout< Once compiled:
*** libmkl_mc.so *** failed with error : libmkl_mc.so: cannot enable executable stack as shared object requires: Permission denied
*** libmkl_def.so *** failed with error : libmkl_def.so: cannot enable executable stack as shared object requires: Permission denied
MKL FATAL ERROR: Cannot load neither libmkl_mc.so nor libmkl_def.so
TimP
Black Belt
This subject has already been discussed at excessive length in this thread. Maybe you could wait 2 or 3 weeks to see whether the compiler update pans out.
Kittur_G_Intel
Thanks Tim for the pointer on the thread with similar discussion and letting him know that this needs to be tested out with the next release
-regards,
Kittur
