I'm getting incorrect results from ICC when attempting to add implementations of the NEON `vabd_s32`, `vabd_u32`, `vabdq_s32`, and `vabdq_u32` functions to SIMDe. Here is a reduced version which shows the problem:
#include <stdlib.h>
#include <stdint.h>
#include <assert.h>
#include <stdio.h>
#include <inttypes.h>
/* It's not necessary to put this in a struct; it just makes it easy
* to switch between a vector and an array for testing.
* When it is an array -O0 and -O1 work, though -O2 fails. As a
* vector it fails even at -O0. */
typedef struct {
#if defined(USE_VECTOR)
int32_t values __attribute__((__vector_size__(16)));
#else
int32_t values[4];
#endif
} vec32x4;
vec32x4 abd(vec32x4 a, vec32x4 b) {
vec32x4 r;
// #pragma omp simd
for(size_t i = 0 ; i < (sizeof(r.values) / sizeof(r.values[0])) ; i++) {
int64_t tmp = ((int64_t) a.values[i]) - ((int64_t) b.values[i]);
r.values[i] = (int32_t) (tmp < INT64_C(0) ? -tmp : tmp);
return r;
int main(void) {
int res = EXIT_SUCCESS;
vec32x4
a = (vec32x4) { { INT32_C( 463415955), -INT32_C( 1803897040), -INT32_C( 1513176249), -INT32_C( 1092402174) } },
b = (vec32x4) { { INT32_C( 2138828797), INT32_C( 1510457891), INT32_C( 1276585996), INT32_C( 1160694450) } },
e = (vec32x4) { { INT32_C( 1675412842), -INT32_C( 980612365), -INT32_C( 1505205051), -INT32_C( 2041870672) } };
vec32x4 r = abd(a, b);
for (size_t i = 0 ; i < (sizeof(r.values) / sizeof(r.values[0])) ; i++) {
if (r.values[i] != e.values[i]) {
fprintf(stderr, "%" PRId32 " != %" PRId32 "\n", r.values[i], e.values[i]);
res = EXIT_FAILURE;
return res;
This is with ICC 2021.1 Beta 20200602 on Linux, x86_64.
Similar code works for other types (i.e., a vector of `int16_t` instead of `int32_t`, with the operations happening on `int32_t` instead of `int64_t`). This happens with both 64 (vabd_{s,u}32) and 128-bit (vabdq_{s,u}32) vectors, with both signed (vabd{,q}_s32) and unsigned (vabd{,q}_u32) integers.
As you can see from the comment in the code, at -O2 and higher it fails if an array is used. If a vector is used, it fails even at -O0. GCC and clang both provide correct results.
I've reported this issue to our compiler Developer.
Viet
This problem doesn't show up with icx. Can you compile with icx instead of icc?
Personally I could, though it's not necessary; I've had a work-around in place since before I posted this. Actually, I just took a look and we use a completely different implementation now.
I'm more concerned about others who might run into this issue with other software. SIMDe has an extremely extensive test suite, which is the only reason I caught this. Others may not be so lucky, and this is a rather nasty issue since it just silently corrupts data… I'd much prefer a segfault or ICE.
The only reason I filed this issue is to let Intel know so you can fix it, hopefully before others run into it without realizing. I know Intel is moving over to icx, but does that mean icc is no longer supported? If that's the case I can drop support for it in my code (and stop reporting bugs), which would definitely make my life a little easier.
We still support icc. It is just that icx has higher priority. So icc issues may take longer time to address.
Hi Evan,
Thanks for reporting the issue. We are closing this thread as icx is working fine. The issue in icc/icpc will be fixed in future releases. Please look out for future releases. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Prasanth
