- Email to a Friend
When using memcpy for unaligned access, ICC generates sub-optimal code. This comes up a lot in data compression; for example LZ4, zstd, LZFSE use memcpy for this (as do a *lot* of other codecs), so they'll be slower with ICC. Yann Collet wrote a blog post about the issue a while back, see https://fastcompression.blogspot.fr/2015/08/accessing-unaligned-memory.html (note that the issues with GCC on ARM have been resolved, so I think ICC is the last hold-out, though I haven't tested MSVC).
Here is a quick test which shows how gcc, clang, and icc handle the same code:
nemequ@peltast:~/t$ cat align.c #include <stdint.h> #include <string.h> uint32_t read32_memcpy(const void* ptr) { uint32_t v; memcpy(&v, ptr, sizeof(uint32_t)); return v; } uint32_t read32_ub(const void* ptr) { return *((const uint32_t *) ptr); } uint64_t read64_memcpy(const void* ptr) { uint64_t v; memcpy(&v, ptr, sizeof(uint64_t)); return v; } uint64_t read64_ub(const void* ptr) { return *((const uint64_t *) ptr); } nemequ@peltast:~/t$ gcc --version && gcc -O3 -c -o align.o align.c && objdump -d -M intel -S align.o gcc (GCC) 6.1.1 20160621 (Red Hat 6.1.1-3) Copyright (C) 2016 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. align.o: file format elf64-x86-64 Disassembly of section .text: 0000000000000000 <read32_memcpy>: 0: 8b 07 mov eax,DWORD PTR [rdi] 2: c3 ret 3: 0f 1f 00 nop DWORD PTR [rax] 6: 66 2e 0f 1f 84 00 00 nop WORD PTR cs:[rax+rax*1+0x0] d: 00 00 00 0000000000000010 <read32_ub>: 10: 8b 07 mov eax,DWORD PTR [rdi] 12: c3 ret 13: 0f 1f 00 nop DWORD PTR [rax] 16: 66 2e 0f 1f 84 00 00 nop WORD PTR cs:[rax+rax*1+0x0] 1d: 00 00 00 0000000000000020 <read64_memcpy>: 20: 48 8b 07 mov rax,QWORD PTR [rdi] 23: c3 ret 24: 66 90 xchg ax,ax 26: 66 2e 0f 1f 84 00 00 nop WORD PTR cs:[rax+rax*1+0x0] 2d: 00 00 00 0000000000000030 <read64_ub>: 30: 48 8b 07 mov rax,QWORD PTR [rdi] 33: c3 ret nemequ@peltast:~/t$ clang --version && clang -O3 -c -o align.o align.c && objdump -d -M intel -S align.o clang version 3.8.0 (tags/RELEASE_380/final) Target: x86_64-unknown-linux-gnu Thread model: posix InstalledDir: /usr/bin align.o: file format elf64-x86-64 Disassembly of section .text: 0000000000000000 <read32_memcpy>: 0: 8b 07 mov eax,DWORD PTR [rdi] 2: c3 ret 3: 66 66 66 66 2e 0f 1f data16 data16 data16 nop WORD PTR cs:[rax+rax*1+0x0] a: 84 00 00 00 00 00 0000000000000010 <read32_ub>: 10: 8b 07 mov eax,DWORD PTR [rdi] 12: c3 ret 13: 66 66 66 66 2e 0f 1f data16 data16 data16 nop WORD PTR cs:[rax+rax*1+0x0] 1a: 84 00 00 00 00 00 0000000000000020 <read64_memcpy>: 20: 48 8b 07 mov rax,QWORD PTR [rdi] 23: c3 ret 24: 66 66 66 2e 0f 1f 84 data16 data16 nop WORD PTR cs:[rax+rax*1+0x0] 2b: 00 00 00 00 00 0000000000000030 <read64_ub>: 30: 48 8b 07 mov rax,QWORD PTR [rdi] 33: c3 ret nemequ@peltast:~/t$ icc --version && icc -O3 -c -o align.o align.c && objdump -d -M intel -S align.o icc (ICC) 16.0.3 20160415 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. align.o: file format elf64-x86-64 Disassembly of section .text: 0000000000000000 <read32_memcpy>: 0: 8b 07 mov eax,DWORD PTR [rdi] 2: 89 44 24 f8 mov DWORD PTR [rsp-0x8],eax 6: 8b 44 24 f8 mov eax,DWORD PTR [rsp-0x8] a: c3 ret b: 0f 1f 44 00 00 nop DWORD PTR [rax+rax*1+0x0] 0000000000000010 <read32_ub>: 10: 8b 07 mov eax,DWORD PTR [rdi] 12: c3 ret 13: 0f 1f 44 00 00 nop DWORD PTR [rax+rax*1+0x0] 18: 0f 1f 84 00 00 00 00 nop DWORD PTR [rax+rax*1+0x0] 1f: 00 0000000000000020 <read64_memcpy>: 20: 48 8b 07 mov rax,QWORD PTR [rdi] 23: 48 89 44 24 f8 mov QWORD PTR [rsp-0x8],rax 28: 48 8b 44 24 f8 mov rax,QWORD PTR [rsp-0x8] 2d: c3 ret 2e: 66 90 xchg ax,ax 0000000000000030 <read64_ub>: 30: 48 8b 07 mov rax,QWORD PTR [rdi] 33: c3 ret 34: 0f 1f 44 00 00 nop DWORD PTR [rax+rax*1+0x0] 39: 0f 1f 80 00 00 00 00 nop DWORD PTR [rax+0x0]
- Email to a Friend
Hi Evan,
I have escalated this to compiler engineering. Will keep you posted on what they say.
Thanks and Regards
Anoop
Topic Options
