Intel® C++ Compiler
ICC ignores type on class variable definition
Bert_Jonson
[cpp]class A {
public:
static int t;
char A::t;[/cpp]
ICC 13 update 1 on windows compiles this code, but mustn't.
BTW:
Why forum is too slow working?
Sometimes it gives:
Gateway Timeout
The proxy server did not receive a timely response from the upstream server.
JenniferJ
Yeh, I can see the issue. thanks for letting us know.
VC2010 and VC2012 will issue an error. icl issued a warning instead. I'll submit to the compiler to look at.
icl warning:
u361639.cpp(7): warning #147: declaration is incompatible with "int A::t" (declared at line  char A::t;
Not sure why the forum server is slow. If it still slow tomorrow, please let me know too.
Thanks!
Jennifer
SergeyKostrov
Valued Contributor II
A static member of a class, even if it is declared with a wrong type 'char', must be initialized with some default value, like: ... class A { public: static int t; }; char A::t = 0; ... So, it looks like there are actually two errors and I'll check what another C/C++ compilers will report. I raise a red-alert and errors like these once are simply not acceptible because the test-case is a classic one.
SergeyKostrov
I'd like to provide results of additional verification. Older version ( 12 ) of Intel C++ compiler also compiles the test-case and at least three test-cases could be considered: [ Test-case 1 ] class A { public: static int t; }; char A::t; Intel C++ compiler: Warning #147: declaration is incompatible with "int A::t" (declared at line 4344) char A::t; ^ Microsoft C++ compiler: Error C2371: 't' : redefinition; different basic types Borland C++ compiler: Error E2356 ... Type mismatch in redeclaration of 'A::t' Error E2344 ... Earlier declaration of 'A::t' MinGW C++ compiler: Error: conflicting declaration 'char A::t' Error: 'A::t' has a previous declaration as `int A::t' Turbo C++ compiler: Error ... Type mismatch in redeclaration of 'A::t' [ Test-case 2 ] class A { public: static int t; }; int A::t; [ Test-case 3 ] class A { public: static int t; }; int A::t = 0;
SergeyKostrov
>>...Why forum is too slow working? Please report any IDZ web-site related issues and problems at: http://software.intel.com/en-us/forums/watercooler-catchall and that forum is monitored by IDZ management.
Georg_Z_Intel
Hello, I've forwarded your feedback regarding the slow IDZ internally. We cannot promise to improve this in a sudden but at least the correct people are aware of it now. Best regards, Georg Zitzlsberger
JenniferJ
This issue is fixed in 14.0 and later. Now ICL also emits the error:
test.cpp(6): error: declaration is incompatible with "int A::t" (declared at line 4)
  char A::t;
Jennifer
