Intel® C++ Compiler
7956 Discussions
ICC inside of MSVC fails to delete zero-sized .obj file when Ctrl+Break is hit at compilation time
Marián__VooDooMan__M
New Contributor II
Greetings,
When I hit Ctrl+Break while compiling, it generates zero-sized .obj file that is at that moment compiled.
Then when I hit F7 (to compile again), ICC doesn't notice that .obj file has zero size, and assumes that this file was successfully compiled. I would expect detection of zero size, and recompile this unit.
Since it deosn't recognize zero-sized .obj file, linker generates (only a) warning(!) something like "file format not recognised" and at the very end of link phase, it produces errors like "unresolved externals", which is obvious.
Workaround:
This is annoying, so I must do search for a zero-sized .obj files, delete them, and then hit F7 to recompile (deleted) .obj files again.
SergeyKostrov
Valued Contributor II
What version of Visual Studio do you use? Please clarify.
Sergey
New Contributor II
It is MSVS 2010, version "10.0.40219.1 SP1 Rel" (from about dialog)
EDIT: It is MSVS 2010 Professional
SergeyKostrov
Quoting VooDooMan
EDIT:
Thanks for the update. Unfortunately, I won't be able to do anything since I don't have VS 2010 Professional Edition ( PE ).
Ioften use"Ctrl+Break" to stop compilationbut Inever experienced any problems with zero-size object files with VS 2005 PE and
VS 2008 PE.
Two workarounds are possible:
- Use Pre-Build Event
Take a look at aProject 'Properties' -> 'Configuration Properties' -> 'Build Events' -> 'Pre-Build Event'
You could use MS-DOS command 'del *.obj' directly orin a bat-file ( a correct path to a folder with object files
has to be specified )
- Clean all Intermediate files before compilation
Sergey
JenniferJ
Which version of Intel C++ are you using?One way tocheck is the "About" dlg.
thanks,
Jennifer
New Contributor II
ICC 13.0,
Intel C++ Composer XE 2013 Package ID: w_ccompxe_2013_beta.0.060
Intel C++ Composer XE 2013 beta Integration for Microsoft Visual Studio* 2010, Version 13.0.1168.2010,
New Contributor II
Now I have noticed the bug is manifesting itself only when "/MP" switch is used, and build is cancelled, there are 4 zero-sized .obj files (probably because I have quad-core CPU).
Om_S_Intel
A test case would help in investigating the issue. Could you please help?
New Contributor II
the test case is any project (MSVC+ICC) with like 10 .cpp files in /MP configuration running on like 4 CPU cores. :-)
Actually, I have found Visual Studio 2010 in MSVC mode (not ICC compiler, but native MSVC compiler) when it is interrupted by Ctr+Break, it will leave zero-sized .obj files of interrupted compilation of it/them. But it will detect it/them, that this/those .obj file/s have zero size, and it will recompile it/them.
IMO, there is bug in MSVC integration, and not in ICC.
IMO it would be nice, in MSVC integration mode, if ICC could detect zero-sized .obj files, and recompile them, as they are obviously unusable for linking process...
New Contributor II
Sergey
VooDooMan wrote:
ICC 13.0,
ping? any new news? the bug is extremely easy to reproduce when you have more than 1 core/CPU's and hit Ctrl+Break. It happens all the time -> Now I am using MSVC 2012 Ultimate under Win8 x64, ICC 13.0.1 (package number #119) and when I hit compile when using "/MP" option, there are at most 4 zero-sized .obj files (since I'm on 4-core Intel), but at least one, and sometimes zero... like a race... But most of the times, like 90% I get 3 zero-sized .obj's (not counting ipo_*.obj file, which is harmless at rebuild), which ICC will not rebuild, since it thinks, it has been already build (as the file IS present, not regarding IT HAS ZERO SIZE), a therefore linker blows into message like object file format not recognised (of course, since it is zero-sized). ICC should test .obj's for zero-size (and rebuild them), and/or at Ctrl+Break in MSVC IDE it should correctly delete these .obj files that have been written in assumption they will be correctly compiled to the end, not to the zero-sized *.obj file at the moment of break without flushing the binary file.
New Contributor II
Quoting VooDooMan It is MSVS 2010, version "10.0.40219.1 SP1 Rel" (from about dialog)
EDIT:
VS 2008 PE.
Sergey
Hi Sergey, unfortunately, your proposed solution is a workaround, not a serious solution. E.g. MSVC without ICC integration have absolutely no problems like this. And PS, I too often hit Ctrl+Break...
SergeyKostrov
Hi, >>...unfortunately, your proposed solution is a workaround, not a serious solution... I agree and it would be nice to hear from Intel Software Engineers if they managed to reproduce that problem. It seems to me so simple "Just hit Ctrl+Break" during some build and I don't understand why 'om-sachan (Intel)' requested a test-case.
New Contributor II
Hi Sergey, we need to wait for Intel to resolve this issue (but maybe the issue is in MSVC IDE logic)... For very large project (200+ .h and .cpp files with more than 1 million source lines this is indeed annoying) best,
SergeyKostrov
>>...For very large project (200+ .h and .cpp files... Did you try to reproduce that problem with a standard VS Wizard Win32 application project ( it has just a couple of .h and .cpp files )?
