Intel® C++ Compiler
7833 Discussions
ICC is short on YMM registers for AVX FLOPs test while GCC runs just fine
Adam_Strzelecki
I wanted to test FLOPs of my CPU using x86 AVX code.
Please find my test tool at https://github.com/nanoant/flops
The code was takes from Mystical at Stack Overflow post.
Please use make CXX=icpc to produce ICC code and make CXX=gcc to produce GCC code.
This syntethic test was created to use all available YMM registers in 64-bit mode. Unfortunately there is something wrong with ICC compiler it does not use all YMM available registers and passes some values via mem back and forth. Moreover the instructions specified as intrinsics are not in the order they are in the source code.
Suprisingly when compiling SSE sample, everything is just fine.
I tested it with ICC 11, 12, and latest 13 Beta both on Mac and Linux to be sure it isn't platform dependent issue. All of them have this problem.
Here is excerpt from objdump -d avxflops-icpc.o
vsubpd %ymm14,%ymm5,%ymm10
vaddpd %ymm12,%ymm2,%ymm2
vaddpd 0x20(%rsp),%ymm12,%ymm3
vaddpd %ymm14,%ymm13,%ymm13
vmulpd 0x40(%rsp),%ymm9,%ymm1
vmovupd %ymm0,0xe0(%rsp)
vmovupd %ymm10,0xa0(%rsp)
vmulpd 0xe5b(%rip),%ymm8,%ymm5
vmulpd 0xe53(%rip),%ymm2,%ymm12
vmulpd 0xe0b(%rip),%ymm11,%ymm8
vsubpd %ymm14,%ymm7,%ymm0
vsubpd 0xe1e(%rip),%ymm4,%ymm7
vsubpd 0xe16(%rip),%ymm5,%ymm11
And here's code generated by GCC 4.7.1, it uses all available registers and all instructions are in the order specified in the code:
vsubpd %ymm2,%ymm13,%ymm13
vmulpd %ymm1,%ymm6,%ymm6
vaddpd %ymm0,%ymm11,%ymm11
vmulpd %ymm3,%ymm4,%ymm4
vsubpd %ymm2,%ymm9,%ymm9
vmulpd %ymm3,%ymm15,%ymm15
vaddpd %ymm0,%ymm7,%ymm7
vmulpd %ymm1,%ymm13,%ymm13
vsubpd %ymm2,%ymm5,%ymm5
vmulpd %ymm3,%ymm11,%ymm11
vaddpd %ymm2,%ymm14,%ymm14
vmulpd %ymm1,%ymm9,%ymm9
vsubpd %ymm0,%ymm12,%ymm12
vmulpd %ymm3,%ymm7,%ymm7
vaddpd %ymm2,%ymm10,%ymm10
vmulpd %ymm1,%ymm5,%ymm5
vsubpd %ymm0,%ymm8,%ymm8
vmulpd %ymm1,%ymm14,%ymm14
vaddpd %ymm2,%ymm6,%ymm6
vmulpd %ymm3,%ymm12,%ymm12
vsubpd %ymm0,%ymm4,%ymm4
vmulpd %ymm1,%ymm10,%ymm10
vaddpd %ymm0,%ymm15,%ymm15
Is there any way to tell ICC to use all available YMM registers and stay away from reordering the AVX code, I tried various optimization levels, none makes the code behave as desired.
Georg_Z_Intel
I took a look at the provided example and can confirm the overhead with superfluous load/store operations. As you're entirely using intrinsics in your loop there should not be any register pressure causing the compiler to save/restore registers. Hence I've filed a defect for engineering (DPD200293901). I'll let you know about the status.
Thank you for your test sample!
Georg Zitzlsberger
