Intel® C++ Compiler
7956 Discussions
ICC xe 2015 + MSVC 2013: GUI: "compiler optimization report" tab is empty
Marián__VooDooMan__M
New Contributor II
Greetings,
I have 2 projects in my solution, but when I press F7 to build, new "compiler optimization report" tab is empty window with only header line.
Any suggestions?
New Contributor II
ping?
New Contributor II
ping again?
MalReddy_Y_Intel
Sorry for late reply, I could able to get the optimization report with ICC xe 2015 + MSVC 2013 on GUI.
For example, I have selected properties->c/c++->Diagnostics[Intel C++]->optimization diagnostic phase->All optimization phases for some test project and got the below report.
Are you looking for any specific optimization report ?
New Contributor II
Greetings,
I have setting ->
Optimization diagnostic phase ==All optimization phases
it is default option, not displayed as a border letter type (i.e. default setting);
MalReddy_Y_Intel
Please check in the below path if you are able to invoke the new "Compiler Optimization Report" window.
#View > Other Windows in VS2013.
Reddy
New Contributor II
Greetings,
Please could you be more specific, and guide me how to enable it?
PS: MSVC 2013
Best
MalReddy_Y_Intel
Open project with MS visual studio 2013--->
           Go to view->other windows->compiler optimization report.
Reddy
New Contributor II
I had this window, but it was empty (only header line was shown).
I had to re-install my laptop for some other issue, and now that window contains ICC's optimization report.
But in the solution there I have 2 projects, and when I build them both, only messages from first project are reported in the window.
Any suggestions?
TIA!
New Contributor II
I think I forgot to set "optimization diagnostic level" to 5 (the highest possible value).
I will post report whether I was successful, but since the project is large and is using many statically linked libraries, it will take some time.
New Contributor II
Yes, that did the trick!
