Intel® C++ Compiler
7873 Discussions
ICE instead of error message on range-based for-loop misuse
Jascha_Wetzel
ICL Version 13.0.1.119 Build 20121008
[cpp]
#include <vector>
int main()
    std::vector<int> v;
    for ( auto& x : v.size() )
        ++x;
[/cpp]
results in
[plain]
missing_error_message.cpp
missing_error_message.cpp(5): internal error: assertion failed at: "shared/cfe/edgcpfe/overload.c", line 8257
[/plain]
Could be a friendlierr error message.
Judith_W_Intel
Thank you for reporting this. This is being tracked in our bug database as DPD200239305. It is fixed in our under development compiler so you should see the fix in our next major release. This will be the error message: !% icl -Qstd=c++11 -c bug.cpp Intel(R) C++ Compiler XE for applications running on IA-32, Version Mainline Bet a Build x Built Nov 21 2012 19:44:17 by jward4 on JWARD4-DESK in D:/workspaces/45cfe/dev Copyright (C) 1985-2012 Intel Corporation. All rights reserved. bug.cpp bug.cpp(7): error: this range-based "for" statement requires a suitable "begin" function and none was found for ( auto& x : v.size() ) ^ bug.cpp(7): error: this range-based "for" statement requires a suitable "end" fu nction and none was found for ( auto& x : v.size() ) ^ compilation aborted for bug.cpp (code 2)
