Intel® C++ Compiler
7782 Discussions
ICE when using OMP before range-for
Jascha_Wetzel
ICC Version 13.0.1.119 Build 20121008
[cpp]
#include <vector>
#include <memory>
class A
public:
    void f(std::shared_ptr<A>)
int main()
    std::vector<int> v;
    auto num = v.size();
    #pragma omp parallel for
    for ( size_t i = 0; i < num; ++i )
        ++v;
    std::vector<std::shared_ptr<A>>
        tmp;
    for ( auto c : tmp )
        c->f(c);
[/cpp]
results in
[plain]
ICE_omp_before_range_for.cpp
ICE_omp_before_range_for.cpp(23): internal error: assertion failed at: "shared/cfe/edgcpfe/checkdir.c", line 5406
[/plain]
Judith_W_Intel
Thank you for reporting this. I have entered this in our bug tracking system as DPD200239307. Judy
Shenghong_G_Intel
FYI. The issue is fixed in v14.x and latest v15.0.
# source /opt/intel/composer_xe_2013.1.117/bin/compilervars.sh intel64
# icc -v
icc version 13.0.1 (gcc version 4.7.0 compatibility)
# icc temp.cpp -openmp -std=c++11 -c
temp.cpp(20): internal error: assertion failed at: "shared/cfe/edgcpfe/checkdir.c", line 5406
compilation aborted for temp.cpp (code 4)
# source /opt/intel/composer_xe_2013_sp1.1.106/bin/compilervars.sh intel64
# icc -v
icc version 14.0.1 (gcc version 4.8.0 compatibility)
# source /opt/intel/composer_xe_2015.1.133/bin/compilervars.sh intel64
# icc -v
icc version 15.0.1 (gcc version 4.8.1 compatibility)
