I'm hitting an ICE with 19.1 20200306 on Linux. Here is a minimal reproducer (courtesy of c-reduce):
typedef float a; struct b { a c __attribute__((__vector_size__(sizeof(2)))); } f; typedef struct { struct b d[2]; } e; void g() { e h; h.d[0] = f; }
$ icc -c -o test.o test.c
test.c(10) (col. 12): internal error: 04010002_1670
compilation aborted for test.c (code 4)
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
While attempting to find a work-around for this I ran into another ICE with a slightly different error code: instead of 04010002_1670, this one triggers 0_1855. The code is *very* similar so I doubt it's a separate issue, but here is the reproducer for that just in case:
typedef char a; typedef struct { a b __attribute__((__vector_size__(sizeof(a)))); } c; typedef struct { c d[2]; } e; e f; void g() { g(f.d[0]); } void main() {}
Please let me know if you need any additional information.
Hi Evan,
We have tried the code you have provided and got the same error as you reported.
We have then checked in the latest beta version of icc and found that there is no error. It seems like the bug is fixed in the newer version of icc.
Meanwhile, before trying the beta version you can use -qnextgen flag which is working.
icc -o out -qnextgen foo.c
This will compile without any error.
Prasanth
Hi Evan,
Thanks for reporting this error.!
We are transferring this issue to the concerned team.
-Goutham
This is a known issue and will be fixed in the next update.
