Intel C++ compiler 16 fails when compiles one of the following code:
int foo = 3; auto boo {foo}; foo = boo + 1;
or
int foo; auto boo {4}; foo = boo + 1;
ICL considers code ill-formed because:
error : no operator "+" matches these operands operand types are: std::initializer_list<int> + int foo = boo + 1; ^
Therefore it deduces type of `boo` to `std::initializer_list<int>`. This violates '7.1.6.4 auto specifier [dcl.spec.auto]':
7 When a variable declared using a placeholder type is initialized, or a return statement occurs in a function
declared with a return type that contains a placeholder type, the deduced return type or variable type is
determined from the type of its initializer. In the case of a return with no operand or with an operand of
type void, the declared return type shall be auto and the deduced return type is void. Otherwise, let T be
the declared type of the variable or return type of the function. If the placeholder is the auto type-specifier,
the deduced type is determined using the rules for template argument deduction. If the initialization is
direct-list-initialization then the braced-init-list shall contain only a single assignment-expression L. If the
deduction is for a return statement and the initializer is a braced-init-list (8.5.4), the program is ill-formed.
Otherwise, obtain P from T by replacing the occurrences of auto with either a new invented type template
parameter U or, if the initialization is copy-list-initialization, with std::initializer_list<U>. Deduce
a value for U using the rules of template argument deduction from a function call (14.8.2.1), where P is
a function template parameter type and the corresponding argument is the initializer, or L in the case of
direct-list-initialization. If the deduction fails, the declaration is ill-formed. Otherwise, the type deduced for
the variable or return type is obtained by substituting the deduced U into P. [Example:...
auto x5{ 3 }; // decltype(x5) is int
—end example ]
This becomes true since C++17, I believe. And for a compiler that doesn't support it, the behavior with code from above is OK. `boo` is `std::initializer_list<int>` in such case.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
This recent language change is implemented in our 17.0 release (currently in beta).
Here's a description the change:
4/14/15
C++14: Direct braced initializers and placeholder types
In C++11 mode, a variable declared with a placeholder type ("auto" or
"decltype(auto)") and with a "direct" braced initializer is deduced to have a
std::initializer_list<...> type. In C++14 mode and in Microsoft C++ mode with
microsoft_version >= 1900, such cases are now only permitted if the braces
enclose a single element and in such situations the outer braces are ignored.
For example:
auto x{ 1, 2 }; // std::initializer_list<int> in C++11 mode; now an error
// in C++14 mode.
auto y{1}; // std::initializer_list<int> in C++11 mode; now int in
// C++14 mode.
This rule is a result of a language change introduced by the C++ standards
committee's paper N3922.
4/14/15
For example:
// in C++14 mode.
// C++14 mode.
