Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
ICL compiler error
I am building a big project and have been getting an error
icl: command line error: multiple sources; object output option must specify dir
Does anyone have any idea about the error.
Highlighted
This error occurs when you are trying to compile multiple files but you expect them to be compiled to one object file, i.e.:
!% icl -c t.c t2.c /Fofoo.obj
Intel C++ Compiler XE for applications running on IA-32, Version Mainline Bet
a Build x
Built Feb 11 2011 15:23:09 by jward4 on JWARD4-DESK in D:/workspaces/cfe/dev
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
icl: command line error: multiple sources; obj output option must specify dir
Microsoft gives this error:
!% cl -c t.c t2.c /Fofoo.obj
Microsoft 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
Copyright (C) Microsoft Corporation. All rights reserved.
cl : Command line error D8036 : '/Fofoo.obj' not allowed with multiple source fi
les
Highlighted
Hey,
Thanks for ur reply. However, I am not sure if that is a problem. I am not compiling 2 files into 1. This build works for Microsoft VC++. What is the meaning of "obj output option must specify dir"? Is there any way to get more information about error?
Thnx
I don't know of any way to get additional help for this option. We have a knowledge base for diagnostics but this one has not yet been filled in.
The /Fo optionsays in the help that it cantake a directory name if multiple files are used, i.e.:
/Fo[file]
name object file (or directory for multiple files; i.e. /FoMYDIR)
but I actually tried this and it doesn't seem to work.
Anyway, please supply a reproducer ... it sounds like a bug in our driverif it works with MSVC++.
thanks,
Judy
Highlighted
Hey,
Is there any chance of getting this error even if we are not using two files to create an object file? I checked my logs and it looks like .obj file has been created by only one file. Please, let me know if such scenarios possible.
Abhi
Highlighted
Hey,
Found the problem. It has nothing to do with compilation of source files. In every compilation of a source file, build was calling a perl script to check versions of files and that perl script had some problem. I removed invocation to that file and it worked.
Weird thing is kind of error message printed by the compiler. I am not sure why such weird error message was given.
Abhi
Highlighted
hey,
I am facing this problem when doing offloading on intel xeon phi coprocessor,it is comiler error
Give me solution as u are more aware with this
1>icl: : error #10036: unable to run 'C:\PROGRA~2\INTELS~1\COMPIL~1\windows\bin\intel64_mic\icc.exe'
1>icl: : error #10340: problem encountered when performing target compilation
