ICL version: 10.1.013
Machine: Quad Core CPU (QX6850 @ 3.00GHz), 4GB RAM, RAID0 HDD
OS: Windows 2003 Server (x64)
After linker starts, it works for about 30 seconds at the same level, memory-wise, and then within 2 minutes goes through 3.5GB of RAM (Available Bytes just plunges to zero in perfmon). Shortly after it hits the paging file, the linker fails with these error messages:
1>Linking... (Intel C++ Environment)
1>(0): internal error: backend signals
1>
1>xilink: error error_during_IPO_compilation: problem during multi-file optimization compilation (code 4)
Is that just a memory leak in the linker or there's a limitation on project size?
Andre
1>
Andre
Try removing IPO (e.g. /GL-). If you would like it investigated, and are willing to submit the case, file a problem report on premier.intel.com.
Like Tim suggested, removing /GL likely solve this issue but may affect your performance.
There's no existing trackers on this. Could you report to PremierSupport?
If you OpenMP, try the compatibility libs in 10.1.
No, there's no OpenMP used. Turning off Whole Program Optimizations and IPO (/Qipo-) didn't help. Only when I reduced the optimization level to /O2, I could compile the project. However, then I ran into another internal error that looks like this:
1>(0): internal error: 0_0
I had to disable optimizations for some source files in order to get past this problem.
Seems that ICL got buggier since I tested one a few months ago.
Andre
Andre
If you can provide a testcase, please submit an issue to https://premier.intel.comso we can investigate the internal compiler errors. You can also try compiling problem routines with /O1 or /Od.
_|ohnO
Out of curiosity (but not just), do you heavily use templates in your code? I got a few internal errors and large memory consumption a few times with my project which has templates and __forceinline functions everywhere... and IPO takes forever.
