Intel® C++ Compiler
ICL emits warning #809 when using defaulted virtual destructors
Ricardo_Costa
The following code:
[cpp]
struct B
    B () = default;
    virtual ~B () = default;
struct D : public B
    virtual ~D () = default;
[/cpp]
generates this warning:
warning #809: exception specification for virtual function "D::~D" is incompatible with that of overridden function "B::~B"
when compiled with: icl /c /Qstd=c++11
I believe this warning is in error since the defaulted destructors should have the same exception specification.
I'm using the latest Intel C++ Composer XE SP1 Update 1 (14.0.1.139).
Judith_W_Intel
Yes this does look like a spurious warning. I have entered this in our internal bug database as DPD200248506.
thank you for reporting it.
Judy
Ricardo_Costa
I see DPD200248506 listed as fixed in Update 2 (https://software.intel.com/en-us/articles/intel-composer-xe-2013-compilers-sp1-fixes-list), however that warning persisted, even in Update 3 and 2015 Beta. Could you verify that?
Ricardo
Judith_W_Intel
Sorry I gave you the wrong tracking number. This is actually DPD200250258 which is still open.
Judy
JenniferJ
an update to this issue. it is fixed in the 16.0 beta. If you'd like to join our beta program, please see Intel® Parallel Studio XE 2016 Beta program has begun
Jennifer
roger567
I am still getting this with 16.0 release 2016.0.110
Marián__VooDooMan__M
New Contributor II
I'm having the same problem with ICC 15.0 (the latest update) when compiling wxWidgets in conjunction with virtual destructors. This warning is negligable, though It's annoying.
New Contributor II
ah, I forgot to say, that wxWidgets project doesn't use c++11 features like "defaulted destructors" for compatibility reasons. So they are regularly implemented destructors, not defaulted.
Ian_Mallett1
I can also reproduce this in version 16.
