Intel® C++ Compiler
ICL not integrated in VS2013
morca
I have installed Visual studio 2013 express and after that, I installed Intel parallel studio XE 2015 trial. Problem is, after installation I don't see any intel compiler button on the toolbars.
TimP
Microsoft doesn't permit other compilers to integrate in express. Vs2013 "community " is the one to use if you're eligible.
morca
But it is stated in the "getting started" that
Accessing the Tools
After installing Intel Parallel Studio XE 2015, access these tools in one of the following methods:
  • In Visual Studio*:
    Open your project in Microsoft Visual Studio* 2010 or higher. The tools are integrated into the Visual Studio menus, and provide toolbars.
JenniferJ
The system requirements are documented in the release notes: https://software.intel.com/en-us/articles/intel-parallel-studio-xe-2015-composer-edition-c-release-notes
During installation, the prerequisite dialog should inform you about the VS IDE integration not available. Did you see that? If not, it'd be a bug in the installation.
Jennifer
