In Intel 2018 Update 1 under VS2017 15.5.0:
Setting /Qintel-extensions- (disable Intel extensions) caused a flood of errors related to decimal floating point values referenced in dfp754.h:
Error identifier "_Decimal32" is undefined sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 55
Error identifier "_Decimal64" is undefined sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 56
Error identifier "_Decimal128" is undefined sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 57
Error identifier "_Decimal32" is undefined sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 58
Error identifier "_Decimal64" is undefined sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 59
Error identifier "_Decimal128" is undefined sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 60
Error "_Decimal32" is not a type name sstask C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\dfp754.h 63
This file is #included at the bottom of <math.h> which is a general purpose #include that should not be predicated upon the presence of Intel intrinsics and extensions. Many standard headers implicitly pull in math.h.
This behavior is new to ICC 18 and does not occur in prior releases.
The source of the error appears to be this preprocessor directive in dfp754.h:
#if (((defined __cplusplus) && ((defined(_GLIBCXX_DECIMAL)) || ((defined(__INTEL_COMPILER)) && ((defined(_WIN32)) || (defined(_WIN64)))))) || ((!defined __cplusplus) && (defined __STDC_WANT_DEC_FP__) && (defined __STDC_DEC_FP__)))
This clause "((defined(__INTEL_COMPILER)) && ((defined(_WIN32)) || (defined(_WIN64))))))" universally qualifies the inclusion of this header for all Windows targets.
Workaround:
Add /D__DFP754_H_INCLUDED to suppress inclusion of this header or enable Intel intrinsics and extensions.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Jason,
Thank you for pointing out the issue and workaround. The problem will be fixed in Update 2.
Jingwei
Hi Jingwei and Jason,
I struggled with this issue, so for the sake of people's health, i'd say that you should on visual studio 2017:
add /D__DFP754_H_INCLUDED to Properties > C/C++ > Command line > Additional options
Cheers and thank you for your workaround Jason.
With new 2018 update i am getting the below error:
Unable to obtain mapped memory
** It was compiling properly in the older versions of Intel parallel studio, after upgrading to latest version IPS2018 Update Pack 1, i am facing this error.
Please let me know on how to resolve this on priority.
