Hi, i'm testing a small program that i've created. it compiles using icpc without any flags and pragmas, but when i want use the OpenMP (with the -openmp flag) i'm getting this error:
[bash] . . . clean done . . . build ltpar.cpp done : ltpar.o . . . building the library libltpar.so done ld: warning: cannot find entry symbol _start; not setting start address /opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so: undefined reference to `pthread_atfork'[/bash]
Also i dont know is related but here is the ld and ldd info of iomp5:
[bash]ldd /opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so linux-gate.so.1 => (0x00528000) libc.so.6 => /lib/libc.so.6 (0x00110000) libdl.so.2 => /lib/libdl.so.2 (0x0052a000) libpthread.so.0 => /lib/libpthread.so.0 (0x003c5000) /lib/ld-linux.so.2 (0x00be1000)[/bash]
[bash]ld /opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so[/bash]
[bash]ld: warning: cannot find entry symbol _start; not setting start address /opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so: undefined reference to `__umoddi3' /opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so: undefined reference to `__moddi3' /opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so: undefined reference to `pthread_atfork'[/bash]
I've done and test everything (see at the bottom) that i've found on this forum and internet, but the problem stills...
I'm using :
icpc (ICC) 12.0.2 20110112
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
icpc (ICC) 12.0.2 20110112Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Environment:
- gcc (GCC) 4.5.1 20100924 (Red Hat 4.5.1-4)
- RHEL 5.5
This is the Makefile:
[bash]CXX=icpc CC=icc LD=icpc CFLAGS=-openmp -liomp5 -pthread LDFLAGS=-openmp -liomp5 -pthread LTPAR_LIB=ltpar OBJFILES := $(patsubst %.cpp,%.o,$(wildcard *.cpp)) all: lib lib: $(OBJFILES) @$(LD) -shared -o lib$(LTPAR_LIB).so $(OBJFILES) $(LDFLAGS) @echo " . . . building the library lib$(LTPAR_LIB).so done" @ld lib$(LTPAR_LIB).so %.o: %.cpp @$(CXX) -c $< $(CFLAGS) @echo " . . . build $< done : $@" clean: @rm -rf *.o @rm -rf *.so @rm -rf *~ @rm -rf *.out @echo " . . . clean done"[/bash]
This is the cpp code (i've not put the .h file ( void corest() ) ):
[cpp]#define ASIZE 2000000 #include#include #include void corest() { float *rowsA = new float[ASIZE]; float *columnsA = new float[ASIZE]; float *rowsB = new float[ASIZE]; float *columnsB = new float[ASIZE]; float *rowsC = new float[ASIZE]; float *columnsC = new float[ASIZE]; for(int i=0; i = (float)rand()* (float)rand(); columnsA = (float)rand() * (float)rand(); } for(int i=0; i = (float)rand()* (float)rand(); columnsB = (float)rand() * (float)rand(); } int procn = omp_get_num_procs(); #pragma omp parallel for num_threads(4) shared(rowsC,columnsC,rowsA,columnsB) for(int i=0; i = rowsA * columnsB ; } for(int j=0; j = rowsA / columnsB ; } } delete [] rowsA; delete [] columnsA; delete [] rowsB; delete [] columnsB; delete [] rowsC; delete [] columnsC; }[/cpp]
Any ideas? something wrong on the linking? i've done everything using -lpthread, -pthread, changing the order of libs, adding the mkl libs, -lpthread_nonshared... Maybe there's something on the linking or the compilation that im not doing.
Is the same behavior using the -parallel flag instead of using the -openmp flag.
Thanks in advance.,
p.s.: the files are attached as a tar.gz.
You need to supply Cruntime libraries to ld to link. Unless you are expert, it is safer to use "icpc" or g++ in place of "ld" to make life easier.
